Oil presure
Old Mar 31, 2007 | 05:35 PM
Robrt32's Avatar
Oil presure
I was going to work Thursday morning and my oil pressure fell to NOTHING. I stoped checked my oil and looked for any leaks eveything was fine. I cranked it back up and listened for any rattling or knocking , lifters or anything out of the norm.. It sounded the same as always. I figured sending unit. I went on to work.. I changed the sending unit and checked the wire running to the best i could.. It still shows NO oil presure. Ive drove it a 100 miles or better , i'm sure its not the pump.. I have bought a aftermarkey gauge to put on it tomorow. just wondering if there is something else to check before i put this on?
Old Mar 31, 2007 | 06:01 PM
operose's Avatar
only way to say is to put the gauge on, I'm afraid.
try not to drive it until you do though, in case you really have no oil pressure
Old Apr 1, 2007 | 04:37 PM
Robrt32's Avatar
I didn't get to work on my truck until late today. I bought a aftermarket gauge yesterday at Advance. I thought all of them came with metric and standard fittings to make it work on almost anything? This 1 did not. It was same size but diffren threads. I'm gonna have to go to Carquest tomorow and see if the can come up with something to fit it.. I think i'm gonna get copper tubing too instead of using that plastic one.. I HAD to drive my truck today too about 60 miles round trip.. SO, i'm positive i have oil pressure or it would be locked up
Old Apr 1, 2007 | 04:43 PM
operose's Avatar
the sunpro gauge I got from autozone had the correct fitting to go in the stock sender location.
if you are concerned about the plastic tubing you could always get an electric gauge like this that has a sender that mounts at the engine so you only have to run a wire into the cab http://www.tooldiscounter.com/ItemDi...e&kw=SNPCP8212
Old Apr 1, 2007 | 04:47 PM
Robrt32's Avatar
The one i have is Sunpro but it only came with 1 brass fitting that screws into the block. I'm thinking it has standard threads and my truck has metric
Old Apr 1, 2007 | 06:33 PM
dcg9381's Avatar
The 22RE has BSP (British Standard Pipe) - some gauge kits come with an adapter that will work.
Old Apr 3, 2007 | 07:29 AM
norcalsvx's Avatar
i have the smame problem if you really did nt have oil presssure you would know it by now.
Old Apr 3, 2007 | 07:49 AM
Yota Tony's Avatar
If he had no oil pressure his engine would have blown or been damaged long ago.
Maybe the factory gauge died, it happens.
Old Apr 3, 2007 | 12:12 PM
Robrt32's Avatar
Do you know or does anybody know which gauge kits come with the right adapter??
Old Apr 4, 2007 | 12:40 AM
Just Learning's Avatar
on my 86 i have autometer and had to order a bsp adapter- call them up and go to autozone and order
Old Apr 4, 2007 | 04:14 PM
longhungsilver's Avatar
and i read that theres a place to install an aftermarket oil pressure gauge right behind the stock one on the 22re?? Is there supposedly a bolt that u can remove then u can thread in the aftermarket one?? i dont see it am i crazy?
Old Apr 4, 2007 | 04:16 PM
Robrt32's Avatar
Yea i noticed 2 on mine , 1 inside the motor mount bracket which would be hard to get to and the 1 under the oil filter
Old Apr 4, 2007 | 04:30 PM
operose's Avatar
I will get the part # of my sunpro kit tonight when I get home, as it worked fine for me
Old Apr 4, 2007 | 04:37 PM
Robrt32's Avatar
Thanks but somehow in the mist of this madness in trying to get this gauge on i have 2 threads and someone has given me the part number
Old Apr 4, 2007 | 04:41 PM
operose's Avatar
yeah I just posted in that other thread too LOL
Old Apr 4, 2007 | 06:34 PM
dcg9381's Avatar
Might want to post that part number up for the next guy that asks the same question.. :-)
Old Apr 4, 2007 | 07:51 PM
operose's Avatar
here is the thread with sunpro and mcmaster carr stuff. https://www.yotatech.com/forums/f116/im-just-loss-now-112007/
Old Apr 5, 2007 | 03:37 AM
Robrt32's Avatar
For future refrence if somebody is having this problem . The part number for the Meteric adapter kit is Sunpro CP7573
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
