Oil presure
Oil presure
I was going to work Thursday morning and my oil pressure fell to NOTHING. I stoped checked my oil and looked for any leaks eveything was fine. I cranked it back up and listened for any rattling or knocking , lifters or anything out of the norm.. It sounded the same as always. I figured sending unit. I went on to work.. I changed the sending unit and checked the wire running to the best i could.. It still shows NO oil presure. Ive drove it a 100 miles or better , i'm sure its not the pump.. I have bought a aftermarkey gauge to put on it tomorow. just wondering if there is something else to check before i put this on?
I didn't get to work on my truck until late today. I bought a aftermarket gauge yesterday at Advance. I thought all of them came with metric and standard fittings to make it work on almost anything? This 1 did not. It was same size but diffren threads. I'm gonna have to go to Carquest tomorow and see if the can come up with something to fit it.. I think i'm gonna get copper tubing too instead of using that plastic one.. I HAD to drive my truck today too about 60 miles round trip.. SO, i'm positive i have oil pressure or it would be locked up
the sunpro gauge I got from autozone had the correct fitting to go in the stock sender location.
if you are concerned about the plastic tubing you could always get an electric gauge like this that has a sender that mounts at the engine so you only have to run a wire into the cab http://www.tooldiscounter.com/ItemDi...e&kw=SNPCP8212
and i read that theres a place to install an aftermarket oil pressure gauge right behind the stock one on the 22re?? Is there supposedly a bolt that u can remove then u can thread in the aftermarket one?? i dont see it am i crazy?
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
