87'22re to 93'22re swap
Old Apr 5, 2007 | 03:42 AM
rebel_soul's Avatar
Exclamation 87'22re to 93'22re swap
My friend swap out his 87' 22re motor and put a 93' 22re motor in his 87' 4x4 truck. The problem is that the temp. guage and gas guage dose not work. When driving, the truck sputters and feels as if there is no power (lagging). The truck is wired up correctly and my buddy said that the harness came of a ""1993""(which i think looks pretty fishey). My friend said that if I changed out the temp. sensor out with a new 93 sensor, the truck would run better and the temp guage would work????? However, when i went to change the temp. sensor I found out the clip on the harness dose not mathch up with the 1993 sensor.
When I look at my friends 1993 truck the clip on the harness looked different from the 87' trucks harness. The sensor from the 1993 truck looked ovaly shaped.
On the 87' truck the harness clips and sensors are more square shaped.
Is there a difference between the two harnesses?
Diffrenet year?
Wrong Wire Harness?
What should I do to make it work correctly?
WTF!!!....PLease help..???
thanks
Old Apr 5, 2007 | 04:18 AM
misterzee's Avatar
The long block is about all those two engines have in common. Best way to swap would be just do the long block from the 93, keep all the induction, harness, ecu etc with the host vehicle. If you still have all those parts.... :-)
Old Apr 7, 2007 | 01:10 PM
rebel_soul's Avatar
if I took the harness from the 87' and put it with the 93' motor it wouldn't work??????
mskalmus
May 28, 2017 07:51 AM
coleypull15
Nov 3, 2015 07:41 AM
steve miller
Oct 10, 2015 01:40 AM
deepmarsh
Aug 6, 2015 03:44 AM
HRDC0R19
Jul 5, 2015 06:43 PM
