whats the stock gearing on an 86 runner?
Old Apr 7, 2007 | 06:10 PM
gixxer_grand's Avatar
like the title says, im also planning on gettin 33x12.50 tires what gearing do i have to go with? manual transmission. how much does it cost rougly to get different gearing?
Old Apr 7, 2007 | 06:35 PM
Sonofmayhem's Avatar
Go with 4.88s for a manual, and 5.29s for an auto, there is a door jam # that will tell you your stock ratio, if not there is.............the test.
Old Apr 7, 2007 | 07:06 PM
Elton's Avatar
for stock more than likely there 4:10s
Old Apr 7, 2007 | 07:31 PM
Stomis's Avatar
I have 4.56's on 33x12.5's and think they are perfect. Honestly I think alot of people overgear here. I plan to keep the 4.56's with 36's and change them out to 4.88's if its too sluggish. I don't blame people for overgearing though stock 22re's and 3.0's are really lacking in power but I dont need my daily driver to be a screamer...
Old Apr 7, 2007 | 08:48 PM
MudHippy's Avatar
So's you get that answer read here, then check the VIN.
http://toyota.off-road.com/toyota/ar....jsp?id=274535
Old Apr 7, 2007 | 10:03 PM
with my truck 4.10s and stock 28s, i could roll 90 down the freeway, with extra power, and climb hills in 5th downshifting to 4th on occasion. And 5.29s will put me close to that with the 35s, if im correct it will actually be a little too low but i figure with the weight increase in the tires/rims it will be damn close.
Old Apr 8, 2007 | 09:08 AM
anyone have a price range on changing gears?
Old Apr 8, 2007 | 09:13 AM
depends, you figure its about 500 just for the gears and install kits, and if you drop your diffs and take it to a shop its like 100-300 per diff, if you take in your whole truck its like 1000-2000 depending on who does it. i have a buddy that does gear install with lockers for 100.
Old Apr 8, 2007 | 10:49 AM
BadYOTA35s's Avatar
i wouldnt even change gears if your gana run 33s...i have stock gears and 35s and have no problems no reason for 5:29 gears on 33s
Old Apr 8, 2007 | 01:29 PM
thook's Avatar
He has a smaller motor, though.
Old Apr 8, 2007 | 01:51 PM
drew303's Avatar
It's reccomended you do 4.88's for 33's . I'm going to run 5.29's and 33's this summer.
I have a Richmond Gear 4.88 Ring n Pinion 7.5 (IFS front) set for $85 shipped.
You're gonna pay around $200 any ring n pinion set. TG has 8" sets for around $130 IIRC. Marlin has Yukon 7.5's for around $185 iirc..
https://www.yotatech.com/forums/f180/richmond-gear-7-5-4-88-ring-n-pinion-112540/
Old Apr 8, 2007 | 02:04 PM
drew303's Avatar
oh and you probably have 4.10's with a 22re manual.
Old Apr 8, 2007 | 05:00 PM
UKMyers's Avatar
Wow that is the only the 4th time this week I've seen this question answered
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
Ichneumon
Sep 27, 2015 04:21 PM
duckhead
Jul 17, 2015 04:45 AM
ACZR
Jun 23, 2015 07:55 PM
