got an ECT mod copy?
Old Apr 5, 2007 | 07:37 AM
javadoody's Avatar
unfortunately, Mark (midiwall) lost his host server, and the page detailing the installation of the ECT Mod on his 96 4Runner Limited along with it (from the Dr.Z post https://www.yotatech.com/forums/show...light=ECT+mod).
did anyone cache the page and pix? i'd like to do it this summer and it would help a great deal to have this info.
many thanks.
Last edited by midiwall; Apr 12, 2007 at 12:14 PM. Reason: MOD edit to remove a last name. :)
Old Apr 7, 2007 | 06:52 AM
javadoody's Avatar
no one's got a copy? anyone want to do a new write-up?
Old Apr 12, 2007 | 08:47 AM
javadoody's Avatar
anyone? that was a nice little mod.
Old Apr 12, 2007 | 08:56 AM
NaeSLaS's Avatar
I don't have any pics, or anything, but i'm an electrician, and could make a small write-up on this. Anyone know what rating potentiometer they were running?
Old Apr 12, 2007 | 12:13 PM
midiwall's Avatar
It was small.. Galen's notes calls for 500ohm, I think I used a 1k pot and any affected adjustment was lost after about 30* of rotation.
The pot just goes in series with the ECT wire. A linear taper pot is highly recommended, as-is tying pin 2 & 3 together on the pot (versus just tying the ECT side to 2 and the ECU side to 1.
Finding the right ECT wire is straight-forward... You're looking for the temp sensor at the FRONT of the engine (on the 3.4 there's another at the rear) and you'll want to intercept the hot wire, not the ground. I think the coloring is GREEN hot and BROWN ground but I'm not sure. A DMM will tell you pretty quick.
There are a couple of ways to "tune" this - Galen's original thread talks about the RPM method, which doesn't require any additional gear. If you wanna be a bit more geeky, you can do it by watching what the ECU is actually doing.
Watching the ECU requires an OBDII reader that will show you STFT (Short Term Fuel Trim). fwiw, the Scangauge II that folks just got done buying through a group buy will NOT show STFT.
Anyway... You fire up the engine, let it warm up (this is important!), plug in the scan tool, and watch the STFT. SLOWLY turn the pot until you see the STFT go UP. This means that the ECU is adding fuel, adding fuel means more power as long as you can add air as well (you'll need the deckplate mod on the 3.4), th ECU will take care of the timing advance. Keep turning until you get to a spot where the ECU stops adding more fuel, this is the place to stop turning.
If I remember right, I think my site showed a pic of an overall add of 7%.
BTW!!! This DOES NOT mean that you just picked up 7% horsepower - it DOES mean that you're burning 7% more fuel than before.
Bottom line... it works to add a bit of kick.
Old Apr 15, 2007 | 02:53 PM
javadoody's Avatar
i posted on the early taco forum and just got the following: http://web.archive.org/web/200511020...unner/ect.html. everything's there but the pix.
Old Apr 16, 2007 | 09:02 AM
midiwall's Avatar
Ahh... Ye Olde Web Archive.
I only wish it would have gone down one more level. Sigh.
Thanks!
Old Apr 16, 2007 | 10:16 AM
shoes138's Avatar
im not sure if i wanna do this cuz of the how much gas is costing now! cost me 45 bucks to fill up my tank!
Old Apr 16, 2007 | 10:23 AM
midiwall's Avatar
Yeup... try having to run premium and getting 10mpg.
Old Apr 16, 2007 | 05:55 PM
shoes138's Avatar
lol DAMN!
Old Apr 18, 2007 | 06:05 AM
midiwall's Avatar
Head's up... I found the pics, the ECT page is back online:
http://www.midiwall.com/4Runner/ect.html
Old Apr 18, 2007 | 06:10 PM
javadoody's Avatar
hey mark, thanks a lot!
Old Nov 27, 2009 | 03:12 PM
nhughes's Avatar
any of you guys know the 22rtec with the a340h trans.? I need help solving a shifting problem after installing an aftermarket engine management system. I had removed the ECU when I installed my SDS EM4-f, as instructed by John @ LCE. Anyone got details on the pins of the ECT?
Old Nov 29, 2009 | 07:24 AM
R.DesJardin's Avatar
A340
You should probably start your own thread with a title to attrack the knowledge base you are searching for, A340 trans. Oh, have you used the search feature or tried a Google search?
TheBFA
Feb 15, 2020 06:55 AM
Longbed 90
Oct 19, 2015 11:05 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 20, 2015 06:15 PM
