squeaky clutch but only when cold
Old Mar 31, 2007 | 11:47 AM
ramos's Avatar
i have searched this alittle, all the squeaky clutch is a constant noise. mine only happens when i first start teh frist time of the day or when it sits for a few hours w/o warming it up first. if i just start and go it squeaks. not in gear and going but when changing gears or when i press down on the clutch. it only lasts a short while, but i didnt know if it was something to worry about or if its something a 91 truck does cuz its old and needs warming. it even happened on a day that it was 80 out leaving work and didnt warm it up.
thanks for the help
Old Mar 31, 2007 | 02:25 PM
drew303's Avatar
Thats the piston in the master clutch cylinder. Does the pedal feel sticky? As in it doesnt slide in and out smoothly but has some hesitation? Sticky piston.
Get a OEM master (marlincrawler.com has both OEM master and slaves).
WD 40 is a good QUICK fix, spray it on the piston rod it will work for maybe up to a week before the squeak returns but the problem will only get worse.
Old Apr 1, 2007 | 02:39 AM
ramos's Avatar
how hard is it to change the master clutch cylinder?
Old Apr 1, 2007 | 04:18 PM
gaboonviper85's Avatar
not at all!!
Old Apr 1, 2007 | 05:48 PM
drew303's Avatar
It's easy. Very easy.
Old Apr 2, 2007 | 10:25 AM
ramos's Avatar
now that i have an idea of what it is it has made any noise. its like she knows, lol.
Old Apr 2, 2007 | 10:28 AM
thook's Avatar
Girls....they always know.
Old Jul 27, 2009 | 03:28 PM
Vicfire's Avatar
Bump!
I just wanted to bump this thread because I am now having the same problem. I have this squeak that comes from the clutch master cylinder piston when the truck is cold. After driving a few miles is goes away. Can I spray lithium grease inside the piston housing? or do I have to replace my master cylinder? The clutch otherwise works great, no problems, just that squeak.
Old Dec 8, 2009 | 08:42 AM
pburke's Avatar
another bump
I may have a similar problem
I get a squeak only when engaging the clutch from a dead stop, getting the vehicle to move. Doing it very slowly seems to not cause the noise at all, but normal driving will cause a squeak.
It seems to go away as things get hot, but I have a hunch it is the clutch disk rather than anything in the hydraulic system. Clutch is now 110k miles old, some slight towing (motorcycle trailer, about 5 times for a few hundred miles), so I guess it may be wearing and only grip better as things expand down there from engine heat.
I don't feel any slip in the clutch, though. So, not knowing if sqeaky sounds are normal signs of clutch disk wear, could it be anything else?
--Oz--
Sep 6, 2015 01:06 AM
Squigglez
Sep 4, 2015 07:33 AM
moparbay
Sep 3, 2015 12:48 PM
northwalker
Sep 3, 2015 12:21 PM
Nick Berg
Sep 3, 2015 04:36 AM
