EFI fuse
Old Apr 3, 2007 | 08:22 PM
david28's Avatar
EFI fuse
I was wondering what the EFI fuse in my fuse box under the hood actually is for. One of my friends told me it was for my fuel pump but im not sure. If I wiggle it back and forth and up and down i can get a solenoid or something to click every once in awhile. What is doing this clicking?? When i go to my friends truck and turn on his key all i have to do is pull out the fuse and put it back in and it clicks. I tried cleaning my fuse connections with an emory board and I pushed the contacts for the fuse towards each other to make sure I was getting a good connection, but still I have no luck. do i need to replace my whole fuse box? thanks in advance.....
David
Old Apr 3, 2007 | 09:53 PM
david28's Avatar
bumps
Old Apr 3, 2007 | 10:27 PM
DeathCougar's Avatar
its for your EFI...hence the EFI fuse. It supplies power to the EFI system from the battery.
Try cleaning the fuse, and the contacts again, and really well. Chances are its all corroded. btw the clicking you are hearing is the EFI Relay in the fuse block.
Old Apr 4, 2007 | 08:10 AM
david28's Avatar
would this fuse being messed up give me problems with my fuel pump?
Old Apr 5, 2007 | 11:52 AM
david28's Avatar
figured it out today...turns out the efi fuse was running my fuel pump. i was able to get a good connection by wrapping one blade of the fuse with a thin piece of metal. now my truck runs great.
Old Apr 5, 2007 | 12:11 PM
TNRabbit's Avatar
You need to go to the dealer & get a replacement ASAP. This is a good way to fry your entire ECU, which will cost a helluva lot more than an EFI fuse.
Old Apr 5, 2007 | 12:52 PM
cweich's Avatar
Is the fuse you are talking about number 90987-02010 other numbers on this fuse are 7567000060. mine is on a 1993 Pickup. When i jump the connection together the truck runs fine.
Thanks
Old Apr 6, 2007 | 06:20 PM
david28's Avatar
i was just getting a bum connection... i dont see how this would fry my ecu??
Old Apr 6, 2007 | 06:23 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
if he only wrapped ONE blade of the fuse with new metal, that won't harm anything. the fuse will still blow if there is a problem. now if he bridged the two blades with metal then yes, that would harm it.
Old Apr 7, 2007 | 09:51 AM
david28's Avatar
yeah....its not bridging the fuse
Old Apr 7, 2007 | 09:55 AM
TNRabbit's Avatar
ah. O K
mreagen
Oct 5, 2015 04:27 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
