shifter issues in 86 5spd tranny
Old 04-01-2007, 12:51 PM
gaboonviper85's Avatar
my friend is installing a clutch in my truck...he said that there are parts like some sort of plate that was compleatly shot...and the seat and bushing was shot....i know about the bushings but i have no idea what he is talking about when he says plate....does anybody have any pics of inside the shifter houseing in a 86 toyota 22r 5spd tranny? also where can i get affordable replacement parts for it cause im sure pepboys doesnt carry it!
is there any write ups about this?
i need as much pics an info as possible if you dont mind im kinda in a hurry to get this truck going cause its my only mode of transportation
Old 04-01-2007, 01:06 PM
Staff
DeathCougar's Avatar
hes talking about the shifter plate taht bolts to the top of the trans. The bushing/seal in the top of that always wears out and breaks apart. You gotta get it at the dealership. If its a carbed truck, it will have 4 bolts holding it down...6 bolts if its EFI
Staff
btw you dont have to remove that plate to replace the shifter seat bushing. It will come out the top.
Old 04-01-2007, 01:14 PM
ok i really have no clue what your talking about...could you call me at 215-356-5294 and give me more details?
he said something about the part that the end of the shifter with the bushing slides into disintragrated...i need pics...
Old 04-01-2007, 01:16 PM
MMA_Alex's Avatar
do a search for shifter seat bushing. might want to edit your post and delete your phone number too lol.
the part that you push down and turn to remove the stick is also shot...so is the boot and spring....i need those also.....i need the shifter seat...the bushing....and he said something about what the bushing slides into inside the transmission being too big and that he things something fell appart.....i dont really know what he is talking about.
Old 04-01-2007, 01:17 PM
naaa i could care less who has my #.....and i did a search and cant find anything that helps....i dont have time to sit and filter threw it all!
Old 04-01-2007, 01:18 PM
its also a prepaid cellphone # so nobody can get any info about me with it lol
Old 04-01-2007, 01:25 PM
Staff
well im not in Philly, so me calling doesn't make sense lol.
If you want, pm me and i willsend you my phone #. Or find me on AIM DeathCougar or yahoo IM Sync14@yahoo.com
Sounds to me like you have answered your own questions tho. The only places you can get these parts are the dealership anyways.
You will need the following parts, from what I can ascertain:
Shift tower bushing
Shifter bushing
Tower gasket
Shifter retainer
Shifter retainer spring
Old 04-01-2007, 01:26 PM
Staff
btw the shifter bushing itself is a white nylon bushing that attaches to the end of the shifter, and cushions between the shifter, and the hole in the trans where the shifter plugs into.
Old 04-01-2007, 01:47 PM
MMA_Alex's Avatar
Shifter bushing info:
Page 1
Page 2
should give you some idea as to what you're talking about atleast
Old 04-01-2007, 04:08 PM
ok more problems.....
my transmission did not have the collar that you push and twist...it has a plate with 4 bolts that holds the stick in.....the plate is rotted and no good....under the plate was a spring and some sort of washer.....
my shifter doesnt look like this http://www.brian894x4.com/Shifter.html
on my firewall it says w46....but my friend looked at the transmissions on marlincrawler and said my transmission looks identical to a w56....he said its the exact same lookin tranny so this is confuseing me!
does anybody have a shifter assembly up for grabs for my transmission...and can anybody point me in the right direction?
this is the tranny he said it looks like... http://www.marlincrawler.com/images/2wd_w56_500.jpg
keep in mind this is for a 2wd truck
Old 04-01-2007, 04:46 PM
bump*
anybody know anything on this transmission?
Old 04-01-2007, 05:42 PM
Staff
that is a W46 trans for sure, the bolt down style. You will need to find the shifter assy that was used on the W series trannys. That should be pretty easy to find. That collar will NOT just slide off, for sure.
Also try posting in the wanted section, or talking to WabFab, im sure he could help you out.
Old 04-01-2007, 10:31 PM
geoff's Avatar
My '88 has the W46 transmission, and I just replaced the shifter bushing the other week - a few pictures at https://www.yotatech.com/forums/f116/acess-so-i-can-remove-shifter-110131/
There are 4 bolts that hold the shifter in, no need to push in an twist to get it out. When I pulled the vinyl floor covering, everything under and around the shifter was pretty clean - not really disintegrating. You need the red W55 shifter seat bushing from Marlin
You might want to try asking on the Marlin forum for any parts you need, since they're in the business of rebuilding the transmissions. See http://board.marlincrawler.com/index.php and scroll down to the specific forum
Old 04-02-2007, 09:33 PM
DAS_GTI's Avatar
I second that. That part is great - better quality than the Toyota one. You can also take your VIN to the Toyota dealer and they will give u the exact printout of your shifter take-apart - that's how I figured it out. There are a couple models, so it helps to give them ur VIN and get the EXACT diagram. Mine was different than the "turn CCW and pull" model.
NOTE: the shifter seat is NOT on the diagram. I was told by the dealer you had to order the complete metal top seat to get the rubber seat, so I would just get the Marlin one...
I recommend getting the printout, taking the shifter assembly out, and seeing what parts you need - then go back and order. Also, when you remove the shifter, watch out for the disintegrated nylon seat - if that falls in ur tranny its no good. Took me about 15 min with a tweezer (with a string tied on it so I couldn't drop that in too) to get it all cleaned up.
Good luck.
Old 04-07-2007, 02:07 PM
well my truck is fixed! i had to get a whole new shifter kit from toyota which ran me $145.....but there was one more problem...in the hole where the end of the actual shifter with the bushing on the ball fits into there is a bushing in there also which was gone....found it in the bottom of the tranny....toyota said there wasnt one in the country so they had to order one from japan so we scraped that idea....turned a piece of brass on the laith and made our own and it works fine!
gotta say what a huge difference in this thing....it had problems with the shifter the day i bought it over 2 years ago....so this is the first time i actually felt a tight shifter stick in this truck!
my clutch actually wore a pocket so to speak int he flywheel so we slaped that up on the cnc milling machine and basicly re contoured the whole flywheel....when the trans was pulled there was a locating dowel pin missing so we made another one on the laith.
thanks for yalls help!!!!
Dieselmann
02-19-2019 02:57 AM
mskalmus
05-28-2017 07:51 AM
yourrealdad
07-21-2015 11:13 AM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: shifter issues in 86 5spd tranny
