2nd Gen 4Runner Rear Upper Shock Brackets
Old Apr 3, 2007 | 12:55 PM
Phalanx's Avatar
A few months ago MarcP had mentioned he found some brackets from a Jeep lift that would convert the upper shock mounting hardware from a "pin" mount to an "eye" mount. I think a few people here have fabbed some up something similar themselves. I was browsing the net and found these pre-fabbed and independent from a lift kit. They are made by Rubicon Express and can be found HERE.
They require that the diameter of the mounting hole be increased by about a millimeter, other than that they bolt right on with a 27mm socket. Now I have a heck of a lot more shock options.
The brackets
Mounted some Bilstien 5150's
Old Apr 3, 2007 | 01:35 PM
Marc P's Avatar
I will be installing mine this weekend if I have time...basically the same brackets you got.
Old Apr 3, 2007 | 01:44 PM
Kiff's Avatar
I like it, looks pretty easy to fab up yourself too
Old Apr 10, 2007 | 04:31 AM
Marc P's Avatar
I put mine on last night.....what a PITA. I always have trouble getting the rear shocks on the lower stem. I still need to tighten things down more. I will get some pics tonight.
Old Apr 21, 2007 | 03:23 PM
Marc P's Avatar
Got mine on with some new MX-6 adjustable shocks...
Old Apr 21, 2007 | 04:41 PM
justinking060310's Avatar
That is an excellent idea. I learned first hand the other day about just how fun it is getting to that upper shock bolt on the passenger side. My only question/concern would be the limiting of travel. is this a factor?
FYI - a Flex Head Angled 3/8" ratchet with a 14mm deep well will fit between the frame rail and the body for those upper shock mounts. Of course, if you have a body lift, you have no issues getting to it. Sorry for the basic info.
Kat
Old May 15, 2007 | 12:47 PM
4Runner92sr5's Avatar
Marc P where did you find the hardware i went to countless hardware shops and i can't find it
Old May 15, 2007 | 04:17 PM
Kiff's Avatar
How much offset do these give? they look to be about 1" or so
Old May 15, 2007 | 05:05 PM
FredTJ's Avatar
Yup, you loose about 1" in compression (upward travel).
Fred
Old Oct 11, 2007 | 07:38 AM
Alex 400's Avatar
So if you put these on with only 1.5" of lift in the back would it be best to just run stock length and travel shocks or extended?
Old Oct 11, 2007 | 11:30 AM
olharleyman's Avatar
How do you like them mx6's I have a set but never put them on just wondering how the ride?? Whats the legth collapsed and extended and what kind of hight is in your rear lift??
AustinTaco
Aug 22, 2022 10:45 AM
Team420
Jan 12, 2021 04:57 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
