5 blinks, then 6.. then pause
Old Apr 7, 2007 | 06:30 PM
thegreydog's Avatar
When re adjusting the valves and timing, I checked the check engine light. It blinked five times then six, then paused, then started over. Is this a 5 and 6 or is this 56. Either way, does anyone know what this means and how do I fix it?
87 Runner
22RE
5 Speed
Thanks
Old Apr 7, 2007 | 06:32 PM
4runnerx3's Avatar
Old Apr 7, 2007 | 06:48 PM
Sonofmayhem's Avatar
NO, but its code 56
Old Apr 7, 2007 | 07:33 PM
thegreydog's Avatar
That is the way I would read it as "56" but I cannot find anything relating to code "56" in the book. After that I was reading "5" and "6", but "5" confused me because it is a brand new o2.
Old Apr 7, 2007 | 09:12 PM
thegreydog's Avatar
Come on guys... Any suggestions?
Old Apr 7, 2007 | 10:08 PM
notanymore's Avatar
if its a new o2 double check that it got pluged in good, or maby you just got a defective one, it happens from time to time
Old Apr 7, 2007 | 11:30 PM
1994runner's Avatar
There is no code 56 on a 87 4runner. I wouldn't worry about the code6.
Check for other reasons to kick the o2 code... is there any vacuum leaks or exhaust leaks ahead of the sensor?
Old Apr 8, 2007 | 12:48 AM
neilan's Avatar
its true there is no code 56 but there is 2 digit codes that your page you posted is not showing. check out this code list it is much more complete, the chart you posted is for older models. http://www.off-road.com/toyota/tech/codes/index.html
Old Apr 8, 2007 | 06:50 AM
thegreydog's Avatar
Thanks a lot. Since I added a header after the HG replacement, the o2 sensor is now down after the collector. I took some wire that matched the gauge of the sensor wire and soldered in a patch wire and shrink wrapped it, almost 3 feet. Is it ok to run it that far?
Old Apr 8, 2007 | 08:04 AM
thook's Avatar
You should get an inexpensive volt/ohm meter and see if it's getting a good signal from the ECU. Search the site on o2 sensor/oxygen sensor. Plenty of good threads on how to do this.
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Scotttekoch
Sep 28, 2015 10:30 PM
zz_denis
Sep 6, 2015 03:43 PM
RobotMoose
Sep 2, 2015 05:53 AM
89Yota4x4RatTruck
Aug 23, 2015 04:05 AM
QuattroDave
Nov 22, 2007 09:37 AM
