How do I get Engine Diagnostic Codes?
Old Aug 26, 2003 | 01:27 PM
QuattroDave's Avatar
HI all,
How do I get the engine computer to spit out the diagnostic codes at me? I know, I can pay a dealer lots of $$$, but there is always a way to do it without the dealer. Federal law requires that a method exist that does not require specialized equipment.
For example, on our other vehicle, you use a clip lead to connect together two terminals under the dashboard, then turn the ignition on, off, on in relatively quick sequence. Then watch the "check engine" light. It will blink a couple of times, then pause, then a couple more times, then pause, then a few more times. Then a long pause. Then the blinking starts again. You write down all these three-digit sequences of blinks and those are the diagnostics.
The procedure is probably written up in the service manual, but said manual is more costly than a repair, so I haven't shelled out the big bucks. I'm hoping that someone else, who likes to pour $$$ in their rig, has said manual and can answer the question.
The truck in question:
1994 2WD "Deluxe". V6 auto-slugmatic. Extra cab.
166,000 miles
Symptom: VERY sluggish engine from a standing start, feels almost like it's misfiring, or not getting fuel. Once the engine is reasonably above idle speed, the power seems normal - weak, but that's standard for this engine/transmission in 1994. "Check engine" light does not come on. Dealer claims it's either normal, or time to rebuild, but doesn't seem to have a clue about how to determine which.
Thanks!
Old Aug 26, 2003 | 01:57 PM
MTL_4runner's Avatar
Here follow this link and you should be all set.
http://www.off-road.com/toyota/tech/codes/index.html
This was true up until 1996.....after that you cannot pull codes on most vehicles without an OBD II code reader.
Old Nov 22, 2007 | 09:05 AM
onesojourner's Avatar
all right thanks. Hopefully I can it done tomorrow and then I will report back with the problem.
Old Nov 22, 2007 | 09:21 AM
Hugo's Avatar
I don't know if OBD1 readers exist, but I paid 52$ for and OBDII read off eBay, which paid for itself many times over now as my CE light comes on daily, I even reset it as I drive now, LOL
Old Nov 22, 2007 | 09:37 AM
Yes, there were OBD I readers but they had proprietary connectors.
OBD II standardized the interface for all vehicles starting in 1996.
smthwsn357
May 1, 2024 07:28 AM
mengquis
Jul 13, 2015 10:39 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Jnkml
Jul 6, 2015 01:20 PM
