Difference between a cracked head and a blown HG
Old Apr 5, 2007 | 11:34 AM
WillRadford's Avatar
Im going to look at a 4runner with a blown HG that a guy is selling for $1050 after work today. He said to me he thinks it either has a blown HG or a cracked head.
I know with a blown HG Im going to see the white smoke out the exhaust and a lack of power. What type of things would I notice if it were a cracked head? How would a head even crack? Overheating? Wouldn't a cracked head be pretty noisy? Wouldn't it be pretty obvious if the head was cracked? I don't think the guy I talked to knew what he was talking about. What can you guys tell me on this?
Old Apr 5, 2007 | 11:37 AM
dcg9381's Avatar
There isn't a good way to tell a cracked head from a HG issue without pulling the head. Cracks can be so small, they're almost impossible to see, even if you know where you're looking... That's why shops pressure test.
Vehicles with blown HGs can run fine... Best way to see how bad it is w/o disassembly is a leak down test..
Old Apr 5, 2007 | 11:39 AM
80W90's Avatar
for that price i would buy it regardless of the reason
Old Apr 5, 2007 | 11:40 AM
kmcc78240's Avatar
I do not know I am sure someone will chime in. But a HG can be replaced and the heads machined down. A cracked head you would need a new head for the engine.you will not intil you take of the head though.
Ya, the body looks pretty good. 212k miles. i found a new head on ebay for $300. Is that a reasonable price? It didn't have any of the valves or anyhting in it but the cracked head would have all of that. I could have it all swapped over.
Old Apr 5, 2007 | 11:54 AM
rdlsz24's Avatar
Heads are cheap. If that is all that is wrong with it, go for it. Go with a head from engnbldr.
Forgot to mention that you can pull the head and have it inspected for cracks, milled, etc, but that will most likely be over $100 right there so you could just put that towards a new one. The only downside to a new head is it can cause your bottom end to go out from the new increase in compression.
Rob
Old Apr 5, 2007 | 12:05 PM
Well, if I buy it, pull the heads and find out that the HG was blown, then there doesn't seem to be any reason to buy a new head. I'd just get the one I pulled cleaned up, milled and the valves reground. It seems super unlikely that the head would crack AND the HG would blow.
Old Apr 5, 2007 | 12:47 PM
UncleBob's Avatar
No, very likely. Blown HG would be the cause of the cracked/warped head.
I guess it all depends on how long it was driven with a bad head gaskets. If it lost all it's coolant and overheated, you can bet the head is toast. If the previous owner killed the engine and towed it home as soon as they saw smoke, it may be ok.
In this kind of deal, plan for the worst (full engine rebuild) and hope for the best (head gasket).
Old Apr 5, 2007 | 12:54 PM
keithguts's Avatar
what year runner are we talking about, and what engine?
Old Apr 5, 2007 | 01:58 PM
surf4runner's Avatar
or a cracked head would cause the HG to fail...
the HG can fail w/o a cracked head, it may warp if overheated though.
the heads comin off, so have it checked before you buy a new one.
Old Apr 5, 2007 | 02:46 PM
1994runner's Avatar
Once the heads are removed, have them pressure tested and resurfaced. There is no way to be certain while the engine is together. A good machinist might be able to weld it if it does have a crack
Old Apr 5, 2007 | 03:03 PM
justinking060310's Avatar
I paid 900 for a 95 4Runner that is beautiful and had a blown HG -- so I would agree that it sounds like a good deal. Always plan for the worst - If your counting pennies it might not be the best project, but if you have the money, tools, and time it is a good project. And i have lots of extra parts you will need
I would pop the oil drain plug and see what comes out. If it's a HG, you should get coolant coming out before oil. The toyota dealer pulled the oil filter for inspection to figure out there was a HG failure on mine as well... Not exactly sure what they looked at thou.
Kat
Old Apr 5, 2007 | 03:21 PM
TC22RE's Avatar
I would be careful replacing a completely rebuilt head on a block with high miles... you may end up stressing the bottom end too much... just a thought, may be a good idea to rebuild the bottom end while you're at it and have a new motor...
A2theK
Jul 12, 2015 10:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
horunner1x
Jul 10, 2015 06:33 AM
87blyota
Jul 10, 2015 04:31 AM
