Racing Seats?
Old Apr 5, 2007 | 07:59 AM
MMA_Alex's Avatar
Racing Seats?
I'm looking at putting in racing seats to replace my beat up buckets. I'm wondering about mounting them. Does anyone make a bracket? or Can i just bolt them down to the floor. Not sure what exactly the mounting patterns are. I know corbeau sells a bracket. Can i use this bracket with other brands of seat? or just corbeau? Does anyone else make a universal bracket?
anyone have pictures of racing seats in their truck so i can get an idea of how they're mounted?
Old Apr 5, 2007 | 08:01 AM
91TPU's Avatar
last time we mounted racing seats in someones car it was recaros, and we re used the old frame rails from the previous seat, a bracket or two, and had them welded to the new seat...
Old Apr 5, 2007 | 08:10 AM
Yota82's Avatar
Race seats are made to be mounted to an in cab roll cage using tabs. I put a set of Beard seats in my buddys Toyota using the stock brackets. All you really need to do is take the stock seat and take the back off and the butt cushion, then you are left with the rails, sliders. If you either make or buy tabs, you can mount the seat to the stock seat frame. The tabs look like shock tabs and they are made to be through bolted with a nut.
Old Apr 5, 2007 | 09:14 AM
UncleBob's Avatar
I've used the Corbeau Baja-SS seats, with the Corbeau Brackets. A very nice seat and worth every penny. I would use them again. A little less expensive than the Beard, but still fully suspended, comfortable, and tough.
http://images.thesamba.com/vw/gallery/pix/160690.jpg
By the way, the Corbeau Brackets are nearly identical to standard poly seat brackets. The standard poly seat brackets are a little less expensive. I'd recommend slider/tilt brackets if going in a 'Runner.
They will mount flat. You can use your old seat frames like Yota82 says, or do some easy fabbing.
Old Apr 5, 2007 | 09:25 AM
norcalsvx's Avatar
sweet mynx you got there
Old Apr 5, 2007 | 09:27 AM
kevin444's Avatar
wedge engineering makes custom brackets for all makes and models.
google them up! kinda pricey but they are popular
Old Apr 5, 2007 | 09:33 AM
UncleBob's Avatar
Thanks. It came a long way. VW's were my other hobby. Some pics of the build (and a few past projects) here:
http://www.manxgallery.org/gallery/2371_Eric
Old Apr 5, 2007 | 11:53 AM
norcalsvx's Avatar
yea i grew up at glamis in one of those, some day i'l get another one-
Old Apr 5, 2007 | 03:24 PM
Trigger's Avatar
Check out PRP suspension seats. A lot of guys on Pirate run them and really seem to be happy with them. If you check out their web site, they make brackets to mount them in different vehicles as well.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
