3 Quick Questions (with pictures)
Old Apr 5, 2007 | 01:46 PM
CanTheWhales's Avatar
Okay, took apart the center dash panel on my 1986 Pick-up 4X4 and I'm trying to figure out what these connections are supposed to go to:
clock?
cigarette lighter?
radio? why two parts?
Old Apr 5, 2007 | 02:31 PM
MudHippy's Avatar
The middle picture is of the cig lighter hook-ups. I'll go see for the clock, don't have a radio either though. Maybe through a process of elimination I can get those wires figured on mine.
Old Apr 5, 2007 | 02:34 PM
881stGenRunner's Avatar
the little red one is the cig lighter, i think the top pic is the clock, the little one next to the cig looks like the power antenna, and in the bottom pic the big connector goes to the radio and the small one goes to the OD on/off light.
Old Apr 5, 2007 | 02:35 PM
olharleyman's Avatar
clock?
cigarette lighter?
# 3 is radio the blue wire is for remote to amp so it turns on with the radio
#1 looks like the clock but mine is a bit different but it is newer as well so clock is most likly the correct answer
Old Apr 5, 2007 | 02:49 PM
Well I'm almost positive that the bigger one in the bottom picture is the radio because four of the wires are blue, green, purple, and pink and on the driver's side there's a set with just purple an pink and on the passengers side there's a blue and green.
I thought the red and white ones in picture two would both be for the cig. light. but if not, how does it ground...also I have a 5-speed so I don't have O/D, would the wires still be there?
Old Apr 5, 2007 | 02:53 PM
the cig lighter is definately the single red one, i know that for sure. All the ones i said, i am pretty confident about, except the last one (the one next to the radio plug)
Even if you dont know whats what, each male plug will match with only the exact opposite female plug.
Old Apr 5, 2007 | 03:06 PM
80W90's Avatar
keep in mind that Toyota installed one wire harness in all the trucks. the difference between a delux and a SR5 is just whats actually connected on that wire harness.
Old Apr 5, 2007 | 03:20 PM
91_4x4runner's Avatar
The top one looks to be the clock plug...
Old Apr 5, 2007 | 03:27 PM
MudHippy's Avatar
The 12V cig lighter has a "+" and a "-" connection. It requires both the red and the white wire shown together (middle pic). You can trust me on it. I replaced mine recently. The red bein' hot IIRC.
jasonty
41
Dec 23, 2018 01:00 PM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
