'92 Tacoma Info Needed.
Old Apr 2, 2007 | 09:50 PM
TrunkLid's Avatar
Hi there!
I just bought a '92 Tachoma X-cab 4cyl 5spd 4x4 that I think is in need of a timing chain.
I haven't had time to really look into it to see if the chain is indeed snapped or if it's something else simple or not, but my question is the 4 banger in there a zero clearance engine or not?
How do I tell which engine it has? They could probably come with more then one 4 banger am I right?
Want to make a cheap lil mud buggy with it.
Thanks!
Old Apr 2, 2007 | 10:23 PM
DeathCougar's Avatar
its not a Tacoma. They didn't start them until 95.5.
The 22RE is an interference engine, which means if you snapped a timing chain, you likely bent valves.
Old Apr 2, 2007 | 10:56 PM
TrunkLid's Avatar
So would it be worth fixing if I had to change the head?
What would a head be worth?
The truck ran and drove fine but it has 511,000kms on it.
Old Apr 2, 2007 | 11:20 PM
depends on what kind of damage was done to it
Old Apr 3, 2007 | 07:31 AM
MMA_Alex's Avatar
pull the valve cover, and see if the chain is snapped or what. also take a look at the guides , and the underside of the valve cover for wear marks.
If the chain did go then you probably have some valve damage. At that mileage its probably worth rebuilding the whole engine, or just getting a rebuild one.
Old Apr 3, 2007 | 02:45 PM
TrunkLid's Avatar
Ok, thank guys!
I'll look into it and get back to you.
This definetly seems to be the place for info on these little things!
Old Apr 3, 2007 | 04:11 PM
Bill's Avatar
if you did bend the valves, you may not need a new head. But if the cain is snapped, the first the you need to do is take the head to a machine shop and have them take a look at it.
I busted a timing chain a little while ago, but I got lucky and didn't bend the valves. If they are bent talk to Ted at www.engnbldr.com and he'll hook you up with new ones.
As far as which engine: it's written on the engine ID plate on the firewall. But if it's a 4x4 and 4cyl, I garuntee it's a 22RE.
Old Apr 4, 2007 | 01:59 AM
TrunkLid's Avatar
Thanks Again!
You guys are great!
Old Apr 4, 2007 | 07:13 AM
maxpower_hd's Avatar
It also depends on how the chain broke in the first place. Most of the time it will need new valves since they usually break while driving down the highway at 70 mph or something. But, I did take a donor motor apart that had a timing chain that broke on start up and the valves never came into contact with the pistons.
That isn't typical though. Either way, I would fix it. Even if you have to buy a whole new head. I seem to remember seeing a price of $380 complete someplace. It may have been engnbldr.com but I'm not sure. Either way Ted there can hook you up.
Old Apr 5, 2007 | 12:57 AM
TrunkLid's Avatar
Man an absolutely complete rebuild kit on eBay is only $370!
Old Apr 5, 2007 | 03:46 AM
MMA_Alex's Avatar
http://www.engnbldr.com/ToyotaHotLicks.htm
Get the metal timing chain guides so the chain wont fall apart again
Old Apr 5, 2007 | 04:41 AM
TNRabbit's Avatar
x2. Definitely DO NOT experiment with ePrey stuff. Ted has a sterling reputation on this and other Yota forums. He currently has a spring sale going on; ask him about it. I got the entire rebuild kit for my 3.0 for $378.00, DELIVERED!
TNRabbit's Avatar
That's spring sale as in SPRINGTIME, not a sale on springs...!
Old Apr 5, 2007 | 06:35 AM
trythis's Avatar
I just ordered a front end rebuild kit from Ted. It comes with a chain, sprockets, timing chain cover, oil pump, water pump, seals, gaskets, and free advice!
Old Apr 5, 2007 | 11:55 AM
TrunkLid's Avatar
Wow! Awesome prices and he takes PayPal! Does he ship to Canada?
Old Apr 5, 2007 | 12:27 PM
Bill's Avatar
He does indeed. I've ordered from him a few times, and his shipping rates are pretty reasonable.
The last 3 orders I got from him only took a week to get to my door, I've got one sitting in customs right now though...dammit...order from Ted.
Old Apr 5, 2007 | 05:29 PM
TrunkLid's Avatar
I sure will!
Thanks Again!
the1998sr5
15
Jul 14, 2020 08:35 PM
treadonmenot
3.4 Swaps
Aug 22, 2015 12:40 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
makemusic116
Aug 2, 2015 05:23 PM
Cplmike
Jul 8, 2015 08:47 PM
