which suspension?
Old Mar 29, 2007 | 03:01 PM
JulsTirn's Avatar
which suspension?
For a 95 4runner which is the best suspension lift out there. Keeping IFS, i know of pro comps, superlifts, tuff countrys. any others. i need opinions of which ones work. all around versatility needed.
Old Mar 29, 2007 | 03:02 PM
Sonofmayhem's Avatar
Total chaos, one of the best if not the best, double your travel.
Old Mar 29, 2007 | 03:10 PM
JulsTirn's Avatar
i want a kit thats not that crazy, front and rear preferably. not to expensive.
Old Mar 29, 2007 | 03:16 PM
mastacox's Avatar
For the most versatility, you're best off getting BJ Spacers, low profile bumps, and possibly bigger t-bars for the front, and 1.5" HD lift coils with panhard relocation bracket in back. Then add a 1" body lift, new longer shocks, and you're golden for 33x10.50's or 33x12.50's with some slight pinch weld modification.
Old Mar 29, 2007 | 03:22 PM
JulsTirn's Avatar
my truck is an automatic, cant find body lift
Old Mar 29, 2007 | 03:45 PM
leebee's Avatar
www.4crawler.com
nuff said!
lee
Old Mar 29, 2007 | 03:47 PM
norcalsvx's Avatar
i run the BJ spacers , OME torsions and run 33x10.50's work great
Old Mar 29, 2007 | 03:48 PM
traben27's Avatar
i can fit the 33x12.50's with 3.75" backspacing on some wheels with my lift.
bj spacers and cruiser coils. search it!
Old Mar 29, 2007 | 04:50 PM
ovrrdrive's Avatar
What is the intended use of the truck?
IE, how often and how hard do you wheel, and what type of wheeling do you do?
And how much lift are you looking for and what size tires do you want to run etc....
Old Mar 29, 2007 | 04:55 PM
91ToyTrck's Avatar
Let's not forget Strapp22 for a complete OME kit w/ BJ spacers.
Old Mar 29, 2007 | 08:06 PM
slosurfer's Avatar
bj spacers and cruiser coils or the kit from strap22 and a 1" body lift from 4crawler. I run the the spacers and cruiser coils with a panhard drop bracket from 4crawler, has worked very well so far. I am adding the body lift soon to alleviate some rubbing because I went to low pro compression bumpstops. Running 33x12.5's and it has been a very good setup for me so far. Also was a way cheaper setup than a drop bracket kit. Also runs well at speeds in the desert, nothing close to a total chaos kit but better than stock.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
