need help fast!!!
Old Mar 30, 2007 | 04:46 PM
91TPU's Avatar
need help fast!!!
ok so im doing some stuff to the truck today, minding my own business, when i notice there is some coolant on the top of my radiator. so i start searching and find a small maybe half inch long hair line crack on the top of the rad by the cap...i need a quick fix that will get me thru a few more weeks, maybe a month...any ideas...i was thinking jb weld it, and then replace it when i can...
ps i have to drive 100 miles tomorrow, and am gonna do something about it tonight
Old Mar 30, 2007 | 04:54 PM
BeaterToyota's Avatar
JB Weld might work, if you can allow enough time for it to harden.
The mounting bracket broke off my radiator one time and I JB Welded it back to the radiator. Lasted years like that.
Old Mar 30, 2007 | 04:56 PM
waskillywabbit's Avatar
Make sure to carry several gallons of water with you on your trip back and get it fixed ASAP cause you overheat your engine and a new radiator will be the least of your problems.
Good luck.
Old Mar 30, 2007 | 04:57 PM
91TPU's Avatar
how long does it take to harden, how does overnight sound? so about 8 to ten hours
Old Mar 30, 2007 | 04:58 PM
MMA_Alex's Avatar
JB Kwik Sets fast. That having been said i dont like jb weld, and haven't had good luck with it, but plenty of people swear by it. Might be able to rtv it? too?
91TPU's Avatar
Good luck.
i was gonna carry like two gallons of water, and another gallon of 50/50 mix prestone coolant with me...
the leak seriously isnt even like drips, it just kinda fizzes out coolant when under pressure
Old Mar 30, 2007 | 04:59 PM
Ringmaster's Avatar
Just drain the Rad. down first, scuff up the surface so Jb has something to grip onto. Overnight would be fine.
Old Mar 30, 2007 | 05:30 PM
faubrunner64's Avatar
i have a leak exactaly like that but mine is super slow ive had it for probably 2000 miles easy
Old Mar 30, 2007 | 05:33 PM
UncleBob's Avatar
That's odd, I do too. Just to the left of the cap. I mean, tiny. Just enough to seep out when hot.
Old Mar 30, 2007 | 05:38 PM
yotaknows's Avatar
Me too. I have let the coolant get down low enough(about 2 inches) so it doesn't seep out as fast. I also check the level every morning and watch the temp gauge. Radiators and head gaskets..the yotas' weak link.
Old Mar 30, 2007 | 07:06 PM
dcg9381's Avatar
JB weld will work for a while. RTV will not (it's under pressure).
A Radiator shop might be able to braze it for you.
A new radiator isn't that bad, around $120 or so.. Radiatorbarn.com
puddlepirate
Jul 30, 2016 06:29 PM
Scotttekoch
Sep 28, 2015 10:30 PM
Project90
Sep 24, 2015 11:40 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
bhaithc
Sep 17, 2015 07:53 PM
