Exhaust stud hole stripped
Old Apr 6, 2007 | 11:54 AM
bad_brains's Avatar
Against forum warning, when installing my new manifold I replaced all the exhaust studs. The installation went great, until the last stud! The bottom-left stud will tighten to a point and then skip back loose. Everything else took the recommended torque.
I got it as tight as I could, and called it done. No leaks. But I'm curious for future reference, what is the recommended fix for this: brazing in the hole and tapping it back to specs, or maybe tapping for a larger stud?
Anybody been there?
Old Apr 6, 2007 | 11:58 AM
all_terrain17's Avatar
Curious too, just noticed the stud I knew was stripped isn't even there anymore
Old Apr 6, 2007 | 12:01 PM
bad_brains's Avatar
My new manifold project was prompted by a blown manifold gasket, cracked manifold, and two missing studs!
Whoa whoa whoa! Easy there fellas. This truck became my problem post-damage.
Old Apr 6, 2007 | 12:10 PM
Yota82's Avatar
That is the most problematic stud. Drill and tap. I think Toyota should have redesigned the head in the 80's and put some steel sleves in ther or something. It's a common problem that needs to be addressed.
Old Apr 6, 2007 | 12:35 PM
TC22RE's Avatar
You may try a helicoil... Or tap for a larger bolt.
Old Apr 6, 2007 | 01:01 PM
thook's Avatar
JB Weld!!!! .......(I jest!)
Helicoil. You can stay uniform on your stud sizes.
Old Apr 6, 2007 | 04:16 PM
bad_brains's Avatar
What size helicoil to stay stock with the studs?
Old Apr 7, 2007 | 12:48 AM
jp123's Avatar
Same thing happened to me when installing my Downey headers. I bought a slightly longer bolt and it worked great. It's been about 2yrs with no problems.
The oem studs are quite shallow. There's probably ~ 1/4 inch worth of un-used threads in the hole.
Helicoil sounds like it would work great too, but it seems like it would be a bit tough to do it right without dropping the engine. It would work well as a last resort.
Good Luck!
Old Apr 7, 2007 | 04:40 AM
thook's Avatar
The next size up. A metric kit should have what you need. Check auto stores around you. It wouldn't be the easiest job, although it's not terribly difficult with the right tools. A right-angle drill, for example. But, try what jp123 suggested first. Just chase the threads of the stud port first with a used stud. Cut a groove (with a dremmel tool or thin cut off wheel) perpendicular to the threads all the way up the stud bolt (creating a channel), spray some PB Blaster on the stud/chaser, and work it in and out easy like to get and traces of rust and whatnot out.
Old Apr 7, 2007 | 05:17 PM
Retapped the threads (M10x1.25 if anyone needs the size), replaced the gasket and missing stud with a new bolt - no more annoying exhaust leak
Only torqued to probably half spec though for fear of stripping the hole again.
Marsheen
Feb 17, 2016 12:29 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
accuracy
Aug 6, 2015 12:32 PM
upongame619
Aug 1, 2015 12:12 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
