PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Busted Rod question.
  2. TPS adjustment and idle adjustment
  3. 22re low idle until you blip the throttle and throttle sticks
  4. leak on 89 runner/changing tranny fluid
  5. 2nd gen 4runner transmission swap
  6. noob to carb: need help fast
  7. Bumper Reinforcment
  8. 88 22re CEL help/code list
  9. Rear Main Seal = how bad???
  10. 22re Knock Sensor signal?
  11. synthetic oil in high milage 22re
  12. Power Antenna from SR5 extra cab fit a 2wd truck.
  13. 1993 pickup What do ya think
  14. 1987 22RE won't idle, runs rough below 2000 rpm
  15. fuel line question......
  16. Show me your rattle can pics and homemade paint jobs
  17. Realistic 22RE Timing Chain Guide Lifespan
  18. 4.88 third
  19. how to id a certain coolant hose?
  20. Rear Window Switch in Cargo Area Mod
  21. Battery light
  22. white 2nd gen PU
  23. Valve Issue. Need some advice.
  24. Exhaust
  25. Roof Rack 88 4runner?Which one and how?
  26. Vibration in the floorboard
  27. no heat inside overheating outside
  28. Tune-up gone bad
  29. Rear diff leaking.
  30. thinking about a tranny swap
  31. Dented Diff
  32. Strange engine tap...?
  33. rebuilt 22re, stumblin alottt
  34. Mounting truck tool box
  35. Differential tube bearings?
  36. Pics of vacuun lines on the 3.0
  37. Found a 86 pickup truck
  38. Cold start issues
  39. Had an idea, tying to get feedback
  40. 850 mile trip in the runner, some issues came up
  41. Rear quarter glass...
  42. Tranny Swap
  43. finished painting
  44. sounds like a plastic bag on my CV
  45. 91 4Runner steering & break problem
  46. 23 spline q's
  47. chevy spring swap no good compress rear
  48. GM Alt Bracket, the one wire hook up?
  49. Loping Idle and stumble when cold - Help!
  50. Need cruise control ID & help 3vz
  51. Armrest Pad Re-do
  52. Wont Stay in 4 Wheel Drive
  53. 3rd Brake Light add to 93 4Runner
  54. oil passages
  55. starter hookup problem!
  56. interior lights :)
  57. Lost Power after playin in the mud HELP.
  58. Worth the hassle?
  59. 1994 Toyota 4wd LOST POWER
  60. Anyone try this muffler
  61. add hub swap
  62. Good lift springs anybody?
  63. 22r w/NO BARK -- Gears or Bolt-on's?
  64. Fuel pump sucking air?
  65. brakes went out/
  66. Anybody looking for a sweet 92?
  67. 1st Gen 4Runner Roof Rack Idea/Install
  68. 1990 toyota four runner doors
  69. Air in fuel line/steam under ex manifold
  70. bugged up electricals
  71. does this bodypart exist?
  72. Problems with running 1/4" wheel spacers on one side?
  73. 3.0 post HG replacement issues
  74. put my rack to use
  75. Door switch and arm rest swap possible?
  76. front engine seal question
  77. oil pump ?
  78. Carb experts - opinion
  79. Time for new wheel cylinders?
  80. anyone have a front diff cover laying around
  81. Air bags for my first gen 4runner
  82. ?on early 90's
  83. 1990: What fuel hose is this?
  84. Need help installing a Tach
  85. Just ordered my cam and head
  86. oil leak question from a newbie
  87. Just installed rebuilt valve cover
  88. 4WD not engaging.
  89. 4WD not engaging.
  90. Which fuel line to where?
  91. misfire/bucking
  92. Anyone use 5w-30 in a 3VZ-E
  93. Tdc
  94. Help Indentify these Gaskets
  95. CV axle decision
  96. first 4runner , with afew issues
  97. cruise control flashing/ high idle???
  98. Need Opinions on Suspension Changes/OME Torsion Bars and Bj Spacers
  99. Smittybuilt 10k winch install 4 4
  100. 92 runner 3.0 starts dies
  101. rerebuilt 22re, no power! :(
  102. Lack of power,sputtering 88 4x4 pickup
  103. I want power windows,any sugestions on kits?
  104. truck won't start...again.....?????
  105. Tired of that broken hoodstick clampy that breaks?! me too!
  106. strange lean condition
  107. australian rig!
  108. 91 3.0 4Runner backfires...
  109. Maybe someone can help?
  110. Best Oil Pan Drain Plug Washer?
  111. Brake Bleeding drivers rear issue
  112. 4runner anti roll bar??
  113. 22re overheating
  114. Prerunner bumper???
  115. Ignition issue
  116. Automatic Transmission "stuttering" - '88 4Runner V6
  117. possibly bad tps?
  118. changing drivetrain fluids and crush washers
  119. Rear Differential Flush
  120. Opinion on repair shop information
  121. Load leveling air bags
  122. land cruiser wheels on a 4runner?
  123. christmas present
  124. slightly rough idle...
  125. Xtra cab on Reg cab frame (for Abeypoo)
  126. CEL code list??
  127. wanna see some pics that'll make you sick?
  128. Changing injectors questions
  129. HELP!! 91 4runner ARB Question
  130. Should I chop the crap out of my truck?
  131. Head Gasket 3.0 problem
  132. Head bolts weeping oil in NEW 3VZE, should I weep also?
  133. Rear bumper cover brackets
  134. Need help now!! Y-pipe cherry red, real hot
  135. Testing a Junk Yard Transmission
  136. Down to 3 yotas.
  137. Mystery Electrical - Starter/Solenoid
  138. i want 35s- what do i needd
  139. 4x2 toyota pickup and 31's?
  140. 1994 fornt grill?
  141. 22re timing cover -> head gasket booboo...
  142. 22RE-C Rubuild Question
  143. 1st Gen 4Runner lockable cargo area
  144. opinions on 5.29 gears
  145. 94 Runner 3.0 Engine Noise
  146. Darn Brakes
  147. v6 heater problems
  148. Isr problem plz help
  149. rear heater removal ?
  150. Small amount of smoke
  151. solid front axel
  152. Oil leak at drive flange?
  153. Brushguard fitment
  154. Need help on parts just got a new clutch.
  155. intake mani gasket;
  156. Truck hates going fast
  157. 86 22rtec having rough idle
  158. Exhaust leaks... new header
  159. possible blown head gasket
  160. Front end conversion from 93' to 91'?
  161. Pickup slider window break-ins!
  162. Car Won't Start - Odd Electrical Output - I have lights but no juice to starter
  163. grinding sound?
  164. driveline vibration
  165. My glasspack took a dump
  166. 22re with no air tube on exhaust manifold why? Is it 22r?
  167. anybody got a pic of 4hummer truck???
  168. 93 Pickup 3.0L V6: Code 14 problem
  169. engine running bad after rain
  170. Distributor pinch-bolt
  171. front end torched supra rear end?
  172. Treaderight retreads
  173. Buying a broken Toyota
  174. Some Transmission Questions
  175. Help finding tail lights
  176. runner vs. pickup
  177. 22re will not idle warm/hot
  178. Junk Yard Find... Need some quick advice.. LOOKn FOR 4.88
  179. Gas millage: filling up a little bit a time Vs. filling up full tank?
  180. Help with repairs!
  181. 88 4-Runner New to me....but needs TLC
  182. wiring harness
  183. Knock Sensor? HELP
  184. Original fuel filter?
  185. 2wd starter vs. 4wd starter
  186. Slave cylinder trick?
  187. Sudden high load / low rpm 'clunk' / knock?
  188. Tie Rods: Do it yourself or Take it to shop?
  189. ECM Pin/wire color code?
  190. lift/tire combination
  191. Truck dying when warm and brakes applied... And foil and copper around exhaust??
  192. Unfindable ticking noise
  193. 3VZE: Can the Oil Pan Be Removed, Engine in Place?
  194. Smittybuilt 10 k winch
  195. What is this? (Picture)
  196. rear window area probs
  197. how many miles are too many on rebuilding block
  198. A new toy (pics)
  199. AC Fast Idle Adjustment?
  200. 5.29 gears and 32" tires
  201. Need Some Advice
  202. Painted my bumpers and other things
  203. How do I fix this radiator issue?
  204. carb guys post pics here
  205. 22RE no compression 3rd cylinder
  206. 3VZ-E Head Removal Snag
  207. Rear Window Relay
  208. slip yoke eliminator?
  209. My 88 3.0 is eating antifreeze again!!
  210. Radiator Boiling? over heating help
  211. clutch slips/can't shift into gear
  212. Hydro locked my runner sat night
  213. speedo issues in 92 pickup
  214. LED Turn Signals
  215. 22re idle air control valve
  216. New engine
  217. 22re exhaust leek get kinda anoying
  218. FINALLY got pics
  219. knuckle bearings, oly wa?
  220. Does anyone know....
  221. Harsh Shifting A340H
  222. Noise coming from rear cabin
  223. 94 3.0 no start
  224. possible to strip head bolts??
  225. B05B Axle Code: 3:15 Gears in my '93 xcab 4x4!!
  226. Big(er) Rims! (pre 3rd gen runner and taco)
  227. OEM Skid Plate Bolts
  228. For cripes sake! boiling coolant!
  229. Cherry red exhaust manifold
  230. 22RE Rear Main Seal
  231. fuel leak HELP!!!
  232. Coolant Loss Mystery Solved
  233. Things to look at/replace while Tranny is out
  234. anyone have before/after pics with body lift
  235. help opening jammed door
  236. buttons on steering wheel?
  237. No compression in 3rd & 4th cyl why?
  238. California motor
  239. youtube video on Seafoam; about 20 yrs old?
  240. drivers side motor hook
  241. Loping with the brakes?
  242. '88 4runner - 22re cooling system disaster - PIC request please!
  243. well that was fun... transmission input shaft seal replacement
  244. head gasket redo.... now no power and....HELP!!
  245. Idle issue, resolved? *not like the others*
  246. Truck dies - igniter and coil?
  247. Stock flywheel weight?
  248. Steering Seal On Firewall
  249. 95 and 97 4runner rearends
  250. Should a new fuel filter rattle?
