Door switch and arm rest swap possible?
Old Nov 21, 2009 | 02:54 PM
Rob2thec's Avatar
I searched, and could not find the answer.
Sooo, Can the front door arm rests, and window/door switches be swapped from a 2nd gen 4-runner into a 1st gen 4-runner?
Both already have power windows and locks.
THANKS!
Old Nov 21, 2009 | 02:56 PM
DeathCougar's Avatar
2nd gen 4Runners were mostly 4 doors.
If you are able to find a 2-door, you could swap them but they would require some serious modification. The switches are not set up the same, so you will at minimum have to figure out wiring.
Old Nov 21, 2009 | 04:07 PM
stormin94's Avatar
You could probably get a voltage tester and figure out the wiring, or get the diagram from a service manual. Then swap out the old harness for the new one that connects to the new switches. It sounds simple, but it'll probably end up being a PITA. I hate wiring.
Old Nov 21, 2009 | 04:47 PM
Rob2thec's Avatar
Ahh.
Yeah I like the Second gen arm rests and switches better. I also hate wiring, and didnt take the 4 door thing into consideration. I just picked up a 1st gen today, guess I am still not used to the 2 door. LOL.
The switch in the 1st gen now is toast. So since i have to already replace it, I was looking at just doing the swap.
Anyone already tried this??
Old Nov 22, 2009 | 12:09 AM
wyoming9's Avatar
Red face
No to the swapping but i have fixed the switches unless it is trashed beyond use .
Does it work at all???
Old Nov 23, 2009 | 12:59 PM
Rob2thec's Avatar
Well, The door locks work fine. However none of the windows will go up or down.
This afternoon I took apart the switch and cleaned all the connection points of residue with some sand paper (like the tutorial on here said). Still nothing. I also checked all the fuses and they seem fine.
Do the relays go bad?
Any other suggestions? Thank god the A.C. and heat work LOL.
Old Nov 23, 2009 | 01:18 PM
Jay351's Avatar
Did you check for power at the switch?
Old Nov 23, 2009 | 01:30 PM
Rob2thec's Avatar
I have not, I dont have any way to check. My friend is going to come by later and bring a volt meter.
BUT the power door locks work fine?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
icentropy
Jul 9, 2015 02:12 PM
Nickdigg
Jul 7, 2015 06:04 AM
