sounds like a plastic bag on my CV
Old Nov 22, 2009 | 02:49 PM
DupermanDave's Avatar
Just like the title says, recently on my driver's side area I notice a sounds like a plastic bag stuck on my front axle. It slows down when the wheel slows down and it only seems to happen sometimes (depends on the temperature.)
I locked the hub to see if that would make any change, and it doesn't. I propped the wheel up on some jacks and turned it to see if I can duplicate it. I cannot.
Any ideas?
Old Nov 23, 2009 | 12:19 PM
No ideas? I'm not joking about the plastic bag noise to get some raised eyebrows. I even tried rolling down the window to see if it I could hear it from the wheel hub. It sounds more like it's from the inner wheel.
Old Nov 23, 2009 | 12:55 PM
Kiroshu's Avatar
Got trees or trash caught up behind the wheel? Your truck is 4WD right....so it does it all the time no matter if its in 2WD or 4WD.... prob bad CV axle replace em. Ball joints? Loose parts? Loose caliper or steering compnents. Dust sheild rattling?
Old Nov 23, 2009 | 01:00 PM
Jay351's Avatar
Have you inspected your wheel bearings?
Old Nov 23, 2009 | 01:02 PM
thedanned's Avatar
Bearings or the spindle is dry? Didnt I read a writeup on how to lube your spindle using a home made tool of some kind on here?
Old Nov 23, 2009 | 01:05 PM
I did check for play in the wheel bearing while I had the driver's side on jacks. That seems fine.
I checked for twigs, branches, trash, etc... and couldnt find anything. I havent tested it in 4wd yet. Just with the hubs locked.
Old Nov 23, 2009 | 01:06 PM
Kiroshu's Avatar
His bearings may be shot.... change em they are prolly due for a servicing anyway.... prolly haven't been done in a while...
Old Nov 23, 2009 | 01:07 PM
thedanned's Avatar
Brake pads? Ive seen em come apart before, or maybe you have a rock or something stuck between the pad and rotor.
Old Nov 23, 2009 | 01:11 PM
Kiroshu's Avatar
Is this noise on turns too? When you checked for wheel bearing play you wiggle the tire top to bottom right? If there is anyplay then your bearings need replacing.... wiggling it left to right will check steering and tierods.... if theres play in there it would be numorus things... inner or outer tierods.... pitman arm....centerlinkage.... idler arm......ect.... sure its coming from that wheel? Brake pads catch any goodies in between them?
Old Nov 23, 2009 | 01:46 PM
Either the wheel or something vibrating under the dash or engine bay.
Old Nov 23, 2009 | 01:52 PM
Kiroshu's Avatar
Something inisde your truck? plastic dash parts of ducts under neither dash? check in engine bay rev the engine and see if something is vibrating...
JNapolitano
Nov 14, 2019 07:46 PM
mussy01
Dec 13, 2016 08:20 PM
altydog
Aug 28, 2015 07:01 AM
juandulce4runner
Aug 21, 2015 01:13 PM
dropzone
Aug 11, 2015 05:16 PM
