No compression in 3rd & 4th cyl why?
Old Nov 15, 2009 | 04:19 AM
4runnerNB's Avatar
I was throwing a Coolant Temp Sensor signal for a few days and it would occasionally cause the engine to buck a couple times, then the light would go out and it would run fine, except when it did that and I was waiting at a stop light and it would stall out and you could smell lots of gas. I'm guessing the sensor floods the engine with gas when it gets a bad signal and it washed out my 3rd & 4th cylinders? Is that a good guess?
I lost those two cylinders all of sudden and was still able to drive it around 30-40km/hr but it was knocking bad. We took the plugs out and 3&4 were black and the compression test confirmed the cylinders were not getting compression. One mechanic I talked to mentioned that cam could have broke in two.
So, should I get a used engine and drop it in or is there anything I should check on first to see if there is an easier/cheaper repair?
Old Nov 15, 2009 | 06:56 AM
peapicker's Avatar
my 2 cents. Im a fan of rebuilding what you have. When done you know exactly what is in your engine and what kind of shape the internals are in. when a used engine is bought, its just a guessing game as to how dependable it is.
Old Nov 15, 2009 | 10:56 AM
thook's Avatar
Cam breaking in two seems rather unlikely. But, you could always pull the valve cover off......pretty easy........and have a look. It's right there on top. I'm assuming 4cylinder?
If the coolant temp sensor goes blah, then yeah......your motor will flood. Seems odd to me that it would only flood on two cylinders, but then I'm no pro. What was the code you were getting exactly? Is it possible you were reading the code wrong?
Old Nov 15, 2009 | 12:53 PM
4runnerNB's Avatar
I believe I read the code correctly. I've got an engine coming from a toyota mechanic who says the head is new, gaskets etc. Hopefully he's being honest about the engine. I'll probably rebuild my old engine just to get the experience and keep my 4runner going for years to come.
Old Nov 15, 2009 | 01:05 PM
Murakami's Avatar
pull the valve cover off and have a look and make sure your valves are all in spec.
Old Nov 15, 2009 | 01:15 PM
thook's Avatar
Oh....that was a rather quick decision. Good luck.
Old Nov 15, 2009 | 04:11 PM
4runnerNB's Avatar
So, if I find my valves aren't in check and I adjust them, is that going to get the engine running again on all 4.... what will that tell me if they're out of whack? I'd really like to find an easier solution than swapping out my engine, but I have to find it soon because my runner is my only vehicle on the road at the moment.
Old Nov 15, 2009 | 06:11 PM
dannomite's Avatar
You could have damage to your head gasket between the cylinders. Which would allow compression to leak into the next cylinder over. Just a thought.
Old Nov 15, 2009 | 08:48 PM
abecedarian's Avatar
1st- find a new mechanic to talk to.
2nd- nice to know you believe you read the code correctly. What was it again?
3rd- no... really... humor us and tell us what the code was...
4th- what were the readings on the compression test? ALL 4 CYLINDERS PLEASE.
5th- adjusting your valves isn't going to help if the cam is broken.
6th- Don't ask for help if all you'll do is waste our time.
Old Nov 15, 2009 | 11:48 PM
JigsN Rigs's Avatar
^ haha harsh reality.. I'm on 3vze I lost all compression on cylinder 1 and it was knocking real bad.. I'm in the process of dissassembly now
Old Nov 16, 2009 | 01:12 PM
4runnerNB's Avatar
I was getting a code 22, engine coolant temp sensor. I know how to properly check trouble codes, but engine internals are not exactly my area of specialty. I've had just about everything apart and back together on 4runners except engines and trannys. I figured someone might have had the same problem and might be able to tell me what they had to fix. I haven't done a compression test myself, I just might tonight when I go drop off my replacement engine. As far as doing a compression test and checking valves I can't think of anything else I can do to see what went wrong short of tearing the engine down, which I will do eventually so I can have a back up that I might juice up a little.
Old Nov 16, 2009 | 06:53 PM
thook's Avatar
Well, causes for compression loss would be busted rings, busted pistons, blown gasket, dead valves, cracked cylinders.......but, it's knocking.
Any smoke? What color, if any?
I'd pull the valve cover and drain the oil......maybe even drop the pan. See if there's any metal in the oil or even a copper tone to it.
Old Nov 16, 2009 | 11:40 PM
JigsN Rigs's Avatar
Yes but if his.rings are shot he would still be getting a little compression. When you have zero compression it could most likely be a busted rod, hole in ur piston, or a valve that is stuck open. I just got the heads off on my 3vze and found my issue was a busted rod. I'm guessing you might be in the same boat.. Good luck yoda
runnermedic
13
Sep 21, 2015 05:20 PM
Yont283
Sep 20, 2015 10:56 PM
themightykhoner
Sep 18, 2015 02:28 AM
AlexJet
Sep 14, 2015 09:00 AM
Yont283
Sep 12, 2015 10:03 AM
