Best Oil Pan Drain Plug Washer?
Old Nov 20, 2009 | 05:43 AM
peckinpah's Avatar
Any suggestions? Every time I look at my drain plug there's a drop of oil hanging from it. I have a leaky rear main seal already, so I really don't need two oil leaks.
I now think I'm using a nylon one I got at an auto parts store, but it's obviously not doing its job. The one that came with the truck worked perfectly, but it got lost during an early oil change and I can't remember what it was made out of.
Old Nov 20, 2009 | 07:33 AM
abecedarian's Avatar
Neither of my trucks (88 4Runner and 91 Pickup, both 22RE's) has a washer / gasket on the drain plug and neither leaks.
Old Nov 20, 2009 | 08:24 AM
rustypigeon's Avatar
I just use the Toyota gaskets from the dealer. I pick a few up whenever I am in there for parts. They are only about .75 a piece and never leak. You are not supposed to reuse them, but I have reused them many times with no problems.
Old Nov 20, 2009 | 08:41 AM
Tubbyfatty's Avatar
You sure its not the oil pan leaking? I have a small drop hanging from my bolt but its my oil pan gasket. Im also using a white teflon (spelling?) washer.
Old Nov 20, 2009 | 03:45 PM
peckinpah's Avatar
Well, I was HOPING it was the drain plug leaking. But since that plug is the lowest-hanging place under there, I suppose any oil leak would tend to accumulate there.
Old Nov 20, 2009 | 04:16 PM
iamsuperbleeder's Avatar
I've re-used the little gasket on my drain plug numerous times. When it's time to replace it, I usually just buy a whole new drain plug from the parts store, and it comes with one, lol, and it's only like $2
Old Nov 20, 2009 | 05:19 PM
Teuf's Avatar
I got a toggle drain years ago, simple schmiple. Lever is spring loaded and recessed. Trail debris has never affected its function.
Old Nov 20, 2009 | 05:50 PM
simple?
what, is it too confusing to use a wrench?
Old Nov 20, 2009 | 06:46 PM
Teuf's Avatar
Not in the least, a finger is not to confusing.
Old Nov 20, 2009 | 06:53 PM
xfactor203's Avatar
Why not just use a rubber O-ring under the head of the drainplug?
Old Nov 20, 2009 | 07:17 PM
mmcpeck's Avatar
When I worked at Nissan we used these copper crush washers on all drain plugs, oil and A/T. I snatched a bunch before I left and have been using them for years, they work great!
I am down to my last one and have no idea where to find them when I'm out after my next oil change. I think any decent cardboard gasket would work fine.
Old Nov 20, 2009 | 09:14 PM
Teuf's Avatar
MM can you take a pic of the last one you have?
Old Nov 20, 2009 | 09:57 PM
ropeman3's Avatar
I have been using RTV sealant on the drain plug before putting the drain plug back in. Never had a leak and cheaper than buying washers.
Old Nov 20, 2009 | 11:04 PM
86tuning's Avatar
The Toyota gaskets are aluminum with a layer of paper on both sides. They work exceptionally well, and are reusable. I won't use anything else.
Old Nov 21, 2009 | 12:41 AM
annoyingrob's Avatar
My buddy who's a toyota mechanic gave me a handfull of those a few years back. They work amazingly well. I use them on all my vehicles.
Old Nov 21, 2009 | 10:26 AM
thedanned's Avatar
JB Weld and never look back
Old Nov 21, 2009 | 10:33 AM
DupermanDave's Avatar
like abe and gnarly, I don't have any gaskets on mine. On my old suzuki sidekick, never had a gasket on that either. On my dad's isuzu truck...no gasket.
Old Nov 21, 2009 | 10:15 PM
Elton's Avatar
i use ShamWow's cut into small circles ...doesn't leak doesn't drip
Old Nov 21, 2009 | 11:33 PM
thedanned's Avatar
sham WOW!
Old Nov 22, 2009 | 12:26 AM
Yotapowa's Avatar
hahaha
