Distributor pinch-bolt
Old Nov 17, 2009 | 10:36 AM
ryoungjohn's Avatar
Hello. This is my first post on this forum. I went through quite a few old threads to find an answer to my simple question, but I think it’s probably just too simple for someone to describe.
I own a 22RE. I just moved from OR to CA and failed the emissions test because my timing was very slightly off. With the TE1 and E1 jumped, rpm reading 850, timing is 3 degrees where it should read 5. All I need to do is rotate the distributor for the adjustment, the only problem is I do not know which bolt is the pinch-bolt.
Can someone please describe (or show in a pic) where the pinch-bolt is?
Thank you!
Old Nov 17, 2009 | 12:46 PM
wyoming9's Avatar
Red face
It is the bolt in the base of the distributor it is on the side facing the firewall there is a slot on the distributor that when the bolt is loose you may adjust the timing
Old Nov 17, 2009 | 03:34 PM
Jay351's Avatar
And there is only one!
Old Nov 17, 2009 | 04:29 PM
ryoungjohn's Avatar
Great. I know which one you're talking about. Thanks for the help!
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
Sam hain
19
Sep 30, 2015 08:25 AM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
