possibly bad tps?
Old Nov 19, 2009 | 11:29 AM
affmondo22's Avatar
possibly bad tps?
Recently, my toyota pickup (3.0 v6) has been idling very poor. It idles very low like it wants to die. When it is doing this, i can see the plunger on what i think is the dashpot moving back and forth? The idle will also smooth out at 1500rpm if i remove the vacuum line going to the dashpot. The last problem is when i hit the gas anymore than about 1/4 throttle, the rpms just drop like it wants to die. Anything under 1/4 throttle acts normal though. The only thing i could think of is a bad tps? Does this sound plausible? I went through some of the resistance checks on it, but the problem doesnt happen until the throttle is opened more than 1/4 throttle and i dont have access to an oscilloscope to check the full range of the sensor.
Here are some pictures of what i am talking about
This is the plunger that was moving back and forth during the terrible idle
And when i removed this vacuum line it idled smooth at 1500 rpm
Old Nov 25, 2009 | 08:10 AM
affmondo22's Avatar
anybody?
Old Nov 25, 2009 | 09:12 AM
blue_CA_yota's Avatar
you can check the resistance across the TPS using a cheap multimeter.. I used my analog multimeter yesterday to adjust my tps.. it worked great..
here is the thread https://www.yotatech.com/forums/f116...stment-197474/
It has a good link within the thread to adjust the TPS..
I does sound the TPS is possible cluprit to your problem, but I have no experience with the 3.0..
smthwsn357
May 1, 2024 07:28 AM
Gone Fission
Jan 12, 2023 10:34 AM
cars-guy
Aug 16, 2020 06:59 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
