?on early 90's
Old Nov 21, 2009 | 09:57 AM
toy_yota34's Avatar
?on early 90's
im looking at buying a 91 pickup. what should i look for that is a widespread problem with these trucks. it is a ext. cab short bed with a 3.0 and a manual transmision. and it still hass the ifs. it is also sitting on 33's. any help on this would be greatly appreciated.
Old Nov 21, 2009 | 10:15 AM
Silver_Truck's Avatar
Sounds like a copy of my truck back in the day! Want to make sure that of course it's been well maintained like any vehicle.
Special things though:
Miles on motor, & if a headgasket has been done on it, last timing belt / water pump / thermostat.
How does the transmission shift, these trucks came with a rubber shift bushing from the factory that tends to wear around this time in its life (if not earlier due to abuse)...an easy 15 minute fix though and Marlin has you covered on good replacement parts.
Has the steering relay rod SST been done?
Honestly just do a good walk around and drive and make sure it looks and feels solid (no leaks, wobbles, vibrations, tracking problems etc.) and these trucks go forever. Mine lived the first 90% of it's life on the road and it went to 390,000 miles before I pulled the motor to do a rebuild and that was only precautionary (had low compression in 1 cyl. but not bad enough to be a real problem yet) and wanted to try to get a little more power before I started to modify the rest (headers, heads port and polished, bigger valves etc). Still factory transmission, transfer case after 415,000 mi and going strong, I'm sure other things would still be factory and without issues had I not chosen to change them (SAS, diff. gears etc.) Good luck!
Old Nov 21, 2009 | 10:59 AM
toy_yota34's Avatar
thank you. that helps alot. you have good lookin truck by the way
Kylenicoll33
Dec 10, 2015 06:43 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
AustinTaco
Sep 18, 2015 08:58 PM
Fofo
Sep 14, 2015 01:39 AM
ToyotaMD
Sep 7, 2015 04:44 AM
