Overflow vacuum not working.
Old Nov 12, 2009 | 10:18 AM
ohyeahcrx's Avatar
Ok so I have my coolant "mysteriously" disapearing. Over the coarse of a week or so my operating temp is higher and higher. When I fill it back up the temp gauge is right where it needs to be. I check the overflow tank and it has alot of fluid in it. Like not just at the "Full" mark, its all the way past that. So based on this knowlege, http://wiki.answers.com/Q/How_does_a...flow_tank_work ive figured that my radiator isnt creating that vacuum to get all the fluid back into the radiator. So do I have a break in the system somewhere? Where all the pressure is escaping out of? New radiatior, new t-stat, new radiator cap. 22re.
Thanks fellas.
Old Nov 12, 2009 | 02:21 PM
ohyeahcrx's Avatar
Anyone?
Old Nov 12, 2009 | 02:28 PM
Kiroshu's Avatar
Check hoses. Turn the truck on and let it run a while, get under it and look for leaks. Check near throttle body and hose coming out of the water pump upper and lower rad hoses..... Loose clamps? Intake manifold gasket leaking..... got smoke out tailpipe?
Old Nov 12, 2009 | 04:31 PM
LITLRED's Avatar
I currently have a small leak from one of the small hoses underneath the intake manifold.
You can check that area by removing the RF tire wheel well cover plate. (4 10mm bolts).
Old Nov 12, 2009 | 06:37 PM
GreyGhost's Avatar
Assuming you don't notice leaking coolant, I would suspect a faulty radiator cap or a leak in the hose inside of the recovery tank, which wouldn't allow coolant to be vacuumed back into the radiator.
Old Nov 12, 2009 | 07:34 PM
ohyeahcrx's Avatar
That sounds like something promising. Could it just be the tiniest of cracks or breakages in that pickup hose?
kawazx636
Oct 6, 2021 03:03 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
zanzabar0
Oct 11, 2015 02:56 AM
scott90
Oct 4, 2015 09:21 AM
