Does anyone know....
Old Nov 15, 2009 | 05:01 PM
some drunk guy's Avatar
Does anyknow or can point me in the link direction of what the year differences are in the 22RE motors. I know what year toyota made the 22re motors, but im trying to figure out what year they swithched conectors onthe wiring harness, and what years match with what...?
Old Nov 15, 2009 | 05:25 PM
camo31_10.50's Avatar
oh jeez...uhmm..i'm pretty sure they're all the same for the most part...
i know alot of people can easily put a '94 22RE into an '85 toyota...so im thinkin they are the same for the most part....im probably wrong though..i got a 22R..LOL
Old Nov 15, 2009 | 05:33 PM
abecedarian's Avatar
The harnesses are mostly the same from 88-95, with most changes due to emissions requirements, injector types and ECU revisions between the years, and 2wd vs. 4wd and auto vs. manual.
If the ECU, harness, sensors and injectors are moved from one vehicle to the next collectively, there are usually no adverse effect to engine operation but 2wd/4wd and auto/stick (as well as which auto or stick) need to be accounted for if you're sourcing a replacement harness for some reason.
Old Nov 15, 2009 | 06:23 PM
Well this is what I have, 1990 4runner, I pulled the 3.0 wiring harness, and I dropped in my 22RE from my 87 truck, I found a 91 4runner 22RE wiring harness that Im swapping in, but the connectors on all the motor sensors and fuel injectors dont match up, so Im wondering what years the connectors where changed, so I can find the injectors and sensors, that will connect right on up...
Old Nov 15, 2009 | 06:24 PM
4runnerx3's Avatar
22re's as the motor goes are pretty much the same. On the harness, 85-87 use one style injector plug and 88 uses a different style. Here are diagrams of the different injector plugs.
85-89 has a bent throttle body and 90-95 has the straight throttle body.
Old Nov 15, 2009 | 07:30 PM
Dood I owe you a beer, thats exactly what I was looking for !
Old Nov 15, 2009 | 08:14 PM
Which years used the resistor for the injector(s) and how does that affect the harness?
Old Nov 15, 2009 | 08:42 PM
weaselman's Avatar
to the throttle body pix. mines an 86 and is not straight...
Old Nov 15, 2009 | 08:47 PM
874runnersr5's Avatar
wierd, my 87 22re is bent and my donor engine from a 91 is straight
Old Nov 15, 2009 | 08:58 PM
Sorry I missed this....
Originally Posted by some drunk guy
... I dropped in my 22RE from my 87 truck...
There you go- use the harness from the 87 and no issues.
Old Nov 15, 2009 | 09:02 PM
DeathCougar's Avatar
Connectors also changed in 1992/3 when toyota made many changes and updates to different systems.
Old Nov 15, 2009 | 09:18 PM
fork's Avatar
Old Nov 15, 2009 | 09:20 PM
Originally Posted by fork
Wow... that's helpful.
Bonus points if you can explain why the early 22re's had the down-turned intake and the later ones didn't.
Old Nov 15, 2009 | 09:23 PM
fork's Avatar
no clue. never seen one newer than 87
also i apologize for the free bump. it won't happen again
Old Nov 15, 2009 | 09:37 PM
That's fine. I don't know either. But the design started because of the 22re's use in the Celica / Supra's which required the down-turn to allow the intake to clear the hood. Why it continued until 89/90 is up for debate since there was room for the straight intake under the hood of the trucks but was probably a result of testing for compliance with US and California emissions requirements.
Old Nov 16, 2009 | 06:17 PM
weaselman's Avatar
i guess i read that backwards. lol..
doesnt help the pictures are reversed from what the text says. lol. im dyslexic. no joke.
Old Nov 16, 2009 | 07:33 PM
waskillywabbit's Avatar
This is a pretty good read:
http://www.toysport.com/technical%20...tech_notes.htm
Old Nov 17, 2009 | 06:52 AM
Well , you know when you pick up a truck and you look under the hood and all the wiring looks basteriezd...aka FUBAR..Well thats what the 87 harness looked like, so I wanted something that was still original and not hacked and spliced...
bwilliams
Dec 2, 2014 06:32 AM
Gevo
Jan 28, 2014 12:33 PM
cobolt23
Jul 4, 2013 10:45 AM
RedneckBatmobile
Apr 6, 2012 09:03 AM
