22RE Rear Main Seal
Old 11-15-2009, 11:33 AM
NHEngineer's Avatar
22RE Rear Main Seal
Does anyone know of a proper tool to install the rear main seal in a 22RE? The biggest diameter in my kit is only about 3 1/8 Ø. The Toyota seal is almost 4" Ø. Any suggestions?
Old 11-15-2009, 11:38 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I had nothing to use to install my last rear main seal. Make sure it's oiled and then take a clean piece of 2x4, lay it across the seal broad side down, and gently tap with a rubber mallet going top to bottom in an even circular path until it's in. Worked for me.
Old 11-15-2009, 11:53 AM
Plumbrbob's Avatar
x2
i jsut used wood and a hammer never had a problem replaced a many of rear seals over the years
Old 11-15-2009, 12:15 PM
NHEngineer's Avatar
The first one I did got kinked so now I'll try again. I used a driver that was way too small in diameter and I tried to drive it in like an outer bearing race. My mistake. As soon I get parts dinosaur to send me another I'll try a different method.
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
Kalihi,HI
07-09-2015 04:29 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 22RE Rear Main Seal
