Some Transmission Questions
Old Nov 17, 2009 | 06:29 AM
wilshire's Avatar
My transmission has been whining in 3rd and 5th. It started doing it about a thousand miles ago. It's got 173k on it now.
I think I'm going to replace it with a used one.
Questions:
1. Any idea of how much time I have or what happens in this situation when it runs out?
2. My truck is a 1990, so it has a W56-C. What years make for a compatible swap?
3. Are there any good write-ups of this job? I've got a haynes manual but I could use a good write-up. Is it a difficult swap to do? Common gotchas that might be overlooked in the manual? Tips and/or tricks?
Old Nov 17, 2009 | 03:45 PM
wilshire's Avatar
No takers on this?
Old Nov 17, 2009 | 06:13 PM
abecedarian's Avatar
Before you get into that, when was the last time the gear oil was drained and replaced?
Old Nov 17, 2009 | 06:42 PM
wilshire's Avatar
I did it when I changed all the fluids when I bought the truck in the spring. Then I did it again a month or so ago to see if redline mt-90 was worth the hype. I'm pretty sure it's good on oil.
Old Nov 17, 2009 | 06:47 PM
Okies. I was only asking.
I'm not sure about which transmissions will be drop in compatible but I'm sure someone will jump in and help with that information.
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
