PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Passenger side gear shaft removal
  2. crankshaft gear problems
  3. Speed sensor compatability
  4. 1987 4Runner 22RE rough idle when cold/high idle when warm
  5. missfire #4 checked valves
  6. do i need a new transfer case
  7. Timing mark jumping, motor dying when taken out of gear
  8. Need help side of road repair auto trany line
  9. Head Gasket Question...
  10. Failed Smog twice. ANOTHER High NOx!!!!! Help PLEASE!
  11. Whining from Speakers, Rough Idle, Check Engine
  12. Rear Shackle Mount Question
  13. died at the stop light
  14. Faint low knocking sound
  15. proud owner of a 1992 runner!
  16. idle
  17. weird brake gremlin
  18. A/t possibly gone ??
  19. Antennae Replacement
  20. Fuel pump failure vs fuel pressure regulator failure
  21. question for a 3.0 alternator
  22. Question with 2wd starter Vs. 4wd starter
  23. Poor Gas Mileage
  24. 92 Toyota PU- Turns over but no start- Fuel Pump?
  25. Help With Broken Door Check
  26. Complete SAS info?
  27. 31x10.50's or LT235/75/15's??
  28. 22re Cold start noise and When letting off of throttle?
  29. Need gauge cluster quick question
  30. Power Steering Belt Tensioner Pulley Bearing
  31. 1987 toyota truck 4x4
  32. 22RE Heads, Options and thoughts??
  33. Rear Bumper compatibility question
  34. Online Parts Source for Older Toyota Trucks
  35. Syncing crank and cam..
  36. Oil Leaking into Rear Brake Drums
  37. Just pulled a 3rd and I'm stumped.
  38. Annoying hesitation/rough idle...thoughts ?
  39. 92 4Runner Steering parts list, names needed.
  40. My first Toyota. Some simple questions.
  41. 94 3.0L 4runner overheating not headgasket
  42. 93 toyota pickup 4x4 front axel cv swap
  43. A/C swap 91 4Runner to 89 pickup
  44. Towing 500 lbs. causes oeverheating
  45. Tach reading wrong!
  46. E-Brake Light Flashes
  47. Question of the day Ebrake prob.
  48. What causes exhaust "popping" during deceleration?
  49. Leaf springs for 87 pickup
  50. 22re and front diff oil leak.
  51. Opinions on rear shackle lift for '93 pickup
  52. pulsation damper question
  53. 1-Crank, 2-Crank, 3-Crank START!!
  54. Battery sits too low
  55. unknown connector in wiring harness
  56. modding a nwor header????
  57. zuk mod = smoother ride?
  58. 1st gen roof rack
  59. One of many problems (tps)
  60. Given 94 4runner - Wonky oil question
  61. Runs Good Till I Have To Really Hit The Gas Pedal
  62. How to fix your passenger sliding seat? Later model 4Runner seats into 1st gen?
  63. Get from 2h 4h
  64. 3.0 5 speed swap, year related compatibility questions
  65. 22re need slight push on gas pedal to start cold
  66. How to Access Back of Fuse/Relay Block
  67. trouble codes and timing for 3vze
  68. leaking manual tranny?
  69. Clutch Slave Cylinder Leak
  70. BUMPERS!!! Lets see them.
  71. What's missing here? Test your knowledge and help a broyota out!
  72. looking for a coffee cup holder fix
  73. Handbrake troubles
  74. 22re running like complete crap (video)
  75. Engine Code 14
  76. Came back home to buy this!!
  77. sold my jeep and bought this!
  78. Mizumo Auto
  79. 22RE Sputters and no power for about 1 min after first starting then runs fine
  80. cylinder misfire input?
  81. Cambob's 22re build thread
  82. 18mm+ wrench for fuel filter?!!? 93 22re
  83. re-assembly time. just about done, but where do these pieces go?
  84. Replacement tailpipe Walker WK44841
  85. Evergreen timing chain kit
  86. how much ac oil?
  87. How To: Clean, Factory Looking LSPV Delete
  88. 92 runner motor swap. Please help!!!
  89. pre-tampered with 88 flat (wont crank)
  90. Enlighten me
  91. Boiling Coolant but not overheating?
  92. Weird Engine Sound (Video), New Battery time, + Rear passenger windows?
  93. oil pressure problem
  94. What is this?
  95. 22re break in procedure
  96. Idler arm, pitman arm, leaky valve cover wohoos!
  97. Backspacing for new wheels
  98. '86 22R-E won't run right!
  99. looking to adjust idle only on 3.0 V6
  100. IFS double cardan clearancing
  101. Starting in wet weather
  102. 3vze no fire need help
  103. 1987 22re cylinder 4 misses when at idle
  104. 1992 3.0 hc (ppm) way too high
  105. Something tugging on steering wheel
  106. 1987 22RE single injector not firing...
  107. Truck won't start as well when warm??? Need advice.
  108. Pulling a 22re block
  109. Car won’t start after warm up??
  110. computer issues blown fuses
  111. 95 4x4 xtra cab 3.0 wont go over 70 mph on highway?
  112. EFI Main relay hot?
  113. new long block smoking issues
  114. Radiator info needed.
  115. how stupid was I? fuel siphon
  116. Rear Tow Hook for 94 4runner
  117. Can't Bleed Rear Brakes!
  118. 93 22re clogged fuel filter or fuel pump? (also starter problem)
  119. Where to get bushings?
  120. 91 4rnr manual xmission - clunk
  121. are v6 standard cabs rare ?
  122. Loose valve guide?
  123. Something fell in my intake replacing manifold gaskets?
  124. Thinking about buying another 4runner. Have some questions
  125. 1986 22re 4x4 pickup
  126. What exactly is happening to my engine when i get code 52?
  127. Radio circuit keeps popping fuses; WHY?!?!
  128. Thud in front end after OME stabiliser and idler arm.
  129. Ivan Ironman Stewarts Toyota V6
  130. AC R12 to R134a Swap and General AC Maintenance 1988 4Runner 22RE
  131. Ignition timing problem after tune up 3vze
  132. Toyota with Land Rover Front End
  133. first yota few questions.
  134. CEL and ECU Headache
  135. going to attempt EGR block, kinda confused
  136. New oil pump creating too much oil pressure? Is it possible?
  137. add a/c to a 3.0?
  138. Cheap Cargo Net
  139. 89 Toyota Pickup with code 52
  140. Pre-89 Floor Mats?
  141. do i have the right o2 sensor??
  142. lift question?
  143. Hooked jumper cables up wrong, now it wont start
  144. '89 22re big 3 jaguar alt. swap help
  145. RIP 88 4 runner
  146. Arb Bumper Compatibility
  147. What do you know about timing?
  148. 3.slow, really, that slow?
  149. 92 Pickup Starting problems
  150. SAS parts interchange
  151. Driving Without cv axle/front diff
  152. Intermittent Ignition after Seafoam
  153. Code 62, Overdrive light, shifting issues
  154. Fuel damper wrench size..
  155. Can I put 2012 shocks on an 87???
  156. Rear Window size
  157. 22re cam timing question
  158. Bypass the neutral safety switch??
  159. 22re engine to tranny mounts??
  160. No spark issue 1990 3vze
  161. Motor ideas
  162. squeak squeak squeak! unknown source at 10 MPH when slowing down, 93 pickup
  163. Bluest DIY paint job ever!(after some much needed rust control)
  164. 89 rear end in a 90 pickup
  165. 87 22re wiring issue. I'm stumped!
  166. '92 DLX to standard bench seat swap?
  167. coolant issue
  168. Tightening the shift pattern in a '93 Pickup
  169. 22re head to timing cover bolt not lining up!
  170. Coolant over pressurizing
  171. 1995 3vz v-6 Fuel Rail Part ID and Part # Help
  172. can oil pan leak also have " rear main seal leak" signs?
  173. New to Toyota Trucks, have an opportunity to buy, appreciate input
  174. What 22re head?
  175. rear end swap
  176. fj80 lift spring height on 4runner
  177. Turn signal flasher location - HELP!!
  178. 85 4Runner to 86 Pickup Bucket Seat Swap Issues
  179. cyl #4 not fireing ?
  180. 94 toyota pickup transfer case leaks while in 4x4
  181. 22rte help!!!!!
  182. Change Speedometer Gear ???
  183. She aint putting out!!
  184. Heater/AC Fan, interesting problem
  185. Steering shaft extension woes... Help? (pics)
  186. 3.0 rebuild?
  187. 87 22re will crank but not start :(
  188. 3rd gen radio in 1st gen 4Runner
  189. New head gasket, smoke and water
  190. need some help!!!
  191. engine swap computer questions
  192. Cylinder #1 (and the rest of the pass. side) Spark plug replacement tips
  193. Death wOobBLe
  194. o2 sensor on 1987 22r
  195. 89 later plenum swap to 88 22re problem
  196. Bad diff from Marlin?
  197. 1992 toyota pickup 3vze auto tranny Major Problems!!!!!!!!!!!
  198. Lower balljoint bolts backed out
  199. 1992 toyota pickup 3vze auto tranny Air Flow Meter Problems
  200. Shift Lever Removal
  201. spare tire changing kit?
  202. acura 90a alternator on 22re
  203. Just how bad are Pacesetter headers?
  204. how do take out the rear window of 87 toyota reg cab
  205. Factory "Jack" Kit for 1986 SR5 Xtracab Question(s)
  206. 1992 toyota pickup automatic tranny 3vze code 24
  207. This "thing" fell out of my truck and I have no idea what it is.
  208. Let's fix another 22RE misfire/backfire/stumble
  209. 1992 3vze dieing problem
  210. the color of metal \m/
  211. Thorley and flowmaster 60,Quiet?
  212. Steaming without overheating?
  213. Having to manual shift my automatic.
  214. O/d switch
  215. Coilover tower brace with 3.0L - no bodylift?
  216. New Pickup owner on the block
  217. Gas with dirt added, where should I start?
  218. giving up 86 4runner
  219. Horn Dont Work
  220. Same Jack used in 86 and 88?
  221. heater fan only blows on low
  222. Rear Window Woes...
  223. Custom radio/cb box?
  224. squeaky ac
  225. OEM 2nd gen wheels with ADD
  226. 90 pickup auto to 5 speed swap
  227. 4 runner rear in a truck...
  228. 88 3.0 4runner A/C Compressor- DIY-able?
  229. Need help identifying a grinding/rubbing sound on my '88 Pickup
  230. Gas gauge reading sporadically or not at all
  231. Fuel pump keeps dying
  232. 92 pickup front end vibration problem
  233. Replace (not convert) R12 to R134?
  234. 3.4 swap Q's
  235. 2nd gen overheating problems
  236. 22RE Radiator Upgrade
  237. 94 22re heating up after stopped
  238. Picture of my spark plugs let me know what you think
  239. engine won't idle and missfires lots
  240. 94 22re backfires and misses
  241. After market gauges?
  242. 3.0 coolant loss
  243. Time for new torsion bars?
  244. 90' 4runner, just need the name for this part
  245. Aftermarket Exhaust suggestions for a 3vze??
  246. Blower Fan fuse problem
  247. A/C working, need help chasing code.
  248. 3rd Yota, need advice
  249. 1986 Toyota SR5 Extra Cab Factory Shelf and Console... Do they really exist?
  250. Timing advance
