Question-O2 sensor wire uhhooked but no CEL?
Old Jul 30, 2012 | 03:51 PM
Fierce Legend's Avatar
The o2 sensor wires are cut and there is nothing hooked up and I dont get a ck engine light. Is this normal?
Anyhow I orderd the denso oem o2 sensor I just want to make sure it will do its job when I plug it in.
Old Jul 30, 2012 | 04:10 PM
dropzone's Avatar
Fossilized
Fixed your thread title.
Are you positive your CEL works?
Also helps to know what year/engine you are working on...(adding this info to your sign is helpful)
Old Jul 30, 2012 | 04:28 PM
rworegon's Avatar
No, not normal. Does the CEL light for a second when you start the rig? It could be the CEL bulb is burnt out. It could be there is something wired in to fool the ECU into thinking the O2 sensor is there and playing nice.
Old Jul 30, 2012 | 05:17 PM
No check engine light comes on when I turn the key or start the engine.
1992 4x4 3vze automatic. The location of the check engine light is on the top of the guage cluster and square right?
All the other stuff lights up. Oil, Seatbelt, rear antilock brakes, A/T temp then they all shut off when I start the motor.
Old Jul 30, 2012 | 05:31 PM
rworegon's Avatar
Looks like on the right according to the FSM:
EG2-169
http://www.ncttora.com/fsm/1990-1995...e/diagnosi.pdf
Old Jul 30, 2012 | 05:51 PM
Ok I looked were the gas guage is because my truck does not have a tach and theres still nothing.
Old Jul 30, 2012 | 05:58 PM
rworegon's Avatar
Sounds like the bulb may be burned out.
raptor510
Feb 17, 2017 07:11 AM
256mbaker
Jul 31, 2015 06:45 PM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
88yodabasket
Jul 13, 2015 01:32 PM
