SAS parts interchange
Old Aug 7, 2012 | 10:25 AM
Rerunn's Avatar
Sup fellas! Gotta steal on a solid axle housing and seeing as I'm gonna completely have to ground up this sucker I was wondering what IFS parts of any could interchange to the solid axle?
The IFS is under a 89 reg cab if that makes any difference but I'm not positive it will. Mainly curious if the locking hubs and calipers could swap over.
Old Aug 7, 2012 | 10:33 AM
OrRunner's Avatar
calipers yes, hubs no.
SEARCH please, this topic has been beat to death on here....
Old Aug 7, 2012 | 10:45 AM
Rerunn's Avatar
Oops...didn't even dawn on me I always forget to search! But thanks for the info.
Old Aug 7, 2012 | 10:57 AM
rattlewagon's Avatar
You should both search apparently.
The hubs IFS hub body can be used on solid axles to widen the stance without wheel spacers. It requires a bit or work to make the breaks line up though.
https://www.yotatech.com/forums/f31/...spacers-59071/
Ive also seen it done with Tacoma rotors in a slip on style.
To get the lockout hubs to fit over the solid axle shafts, you need to get a set of Longfields chromo hub gears made just for that purpose....
Old Aug 7, 2012 | 12:36 PM
OrRunner's Avatar
I am gonna just leave this here.....
Apparently the hub body can work, not the hub as a whole, thus the "IFS HUBS" can not be used.
As you stated, the HUB BODY can, and I guess the spring and such, but the clutch (what ever engages the shaft) can't.
Kinda the whole 27 and 30 spine thing
Sorry for the confusion...I'll go back to lurking again
Old Aug 7, 2012 | 03:29 PM
TrikeKid's Avatar
The wheel hub can be used as well, then you pop some of Bobby's conversion hub gears in and can re-use your old hubs.
Old Aug 9, 2012 | 04:09 PM
Uh. Ya. Thats what I said.
http://www.longfieldsuperaxles.com/p...INNER-HUB-GEAR
http://www.pirate4x4.com/forum/showthread.php?t=884089
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Fundy Rider
Jul 16, 2015 01:35 AM
karbin
Jul 5, 2015 11:37 PM
