Thud in front end after OME stabiliser and idler arm.
Old Aug 8, 2012 | 07:29 PM
Red Wagon's Avatar
I've got a new sound out of the front end of my 92 4Runner after some work.
I put in an Old Man Emu steering stabiliser and new idler arm. I also tightened my steering box.
After I started getting a thud in a corner. Seems more often in a right turn but can't see anything obvious.
I would like some ideas on the culprit as I go on a big trip soon. The stabiliser is a lot bigger than stock. Could it be binding? Anyone else have one in?
Where else should I look to narrow down the search?
Thanks
Old Aug 8, 2012 | 07:36 PM
Truckstarr's Avatar
For what it's worth, I got the full OME lift kit on my '86 and have never had any problems with the stabilizer bar. Sorry, no help.
Old Aug 8, 2012 | 07:38 PM
BigBluePile's Avatar
Does it make this noise when backing up?
Old Aug 9, 2012 | 03:21 AM
Red Wagon's Avatar
No. It doesn't seem to.
Old Aug 9, 2012 | 06:07 AM
Yotard's Avatar
I have the OME stabilizer and don't have any issues on my 95. Get under the truck and have someone turn the wheel and just watch it to be sure. I doubt that is the problem though.
Old Aug 9, 2012 | 07:06 AM
Red Wagon's Avatar
What do you think could cause it? We went under and turned the wheels but could not see anything obvious.
It only happens when driving. I suppose it needs some force to make it happen. It sounds like a hollow thud.
I really hope it's not a bad ball joint.......
Old Aug 9, 2012 | 10:00 AM
Red Wagon's Avatar
So to check my balljoint I need to get the front on jackstands and jack up the lower control arm and give it a wiggle? How can I tell if it's the upper or lower?
Old Aug 9, 2012 | 12:50 PM
Red Wagon's Avatar
Bump for more ideas. My buddy is at my house having a look. I work at a mine site and have a trip two days after I get home. Any parts I might need will need to be ordered asap to not delay my arctic expedition.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
ptb12
Jul 5, 2015 01:49 PM
