oil pressure problem
Old Aug 11, 2012 | 09:22 AM
my 75 toyota's Avatar
Unhappy oil pressure problem
On my 87 22r engine with a rebuild kit runs good now. I used the ENGBLDR kit. My problem is now my oil pressure is all over the place. When at idle it is 10psi or could be 40psi. When i give it some gas the guage sometimes drops to 0 then goes back up and sometimes when i hit the gas it goes up like it should. So i used a WIX oil filter then tryed the fram same problem. I then changed oil pump and still no change. And last but not least i even replaced my mechanical guage with another one as the first one was a couple years old and still have oil pressure drifting. Sometimes while holding rpm at 2500 the guage bounces all over the place any ideals.
Old Aug 11, 2012 | 10:55 AM
ksti's Avatar
Did you prime the oil pump when you replaced it?. I've read that there can be an air block preventing it from picking up adequate oil.
Old Aug 11, 2012 | 12:27 PM
Yes the pump was primed and still after that i,ve run several times there should be no air in it by now. logged about 10 miles on new engine so far.
Old Aug 11, 2012 | 03:45 PM
TNRabbit's Avatar
You have a short in the wiring from the sending unit.
Old Aug 11, 2012 | 04:02 PM
myyota's Avatar
Ive had this happen before, you have a bad oil sending unit.
Old Aug 11, 2012 | 04:47 PM
No i went to a mechanical guage along time ago but bought a new one incase old one was bad
Old Aug 11, 2012 | 06:41 PM
abecedarian's Avatar
When you fill the crankcase, how much oil do you have to put in for the stick to read full?
And don't quote from the manual: say exactly how much oil you put in.
Old Aug 11, 2012 | 06:49 PM
i did not pay attention why
i can change it again im useing penns 10w30 an wix filter
bigjstang
Jun 2, 2025 03:56 PM
jbv808
Aug 6, 2021 04:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
