Hardness using stock buckets.
Old Jul 29, 2012 | 02:09 PM
yotarover's Avatar
Any of you guys, using a 4-5 point hardness with stock bucket seats?
Old Jul 29, 2012 | 02:35 PM
TrikeKid's Avatar
I'm gonna guess that if you have stock buckets, you also don't have a cage to put a harness bar into to safely install them. The shoulder restraints in a 4/5 point harness should never be run back down to the floor of the cab. Just something to think about. The other thing is that should you roll a vehicle with no cage, the stock 3 point belts will let you move enough to not just be crushed by the cab where a harness will keep you upright even if there's no longer room for your head in the vehicle.
Old Jul 29, 2012 | 02:46 PM
yotarover's Avatar
just had thoughts of tying it into a bar running behind the cab. these stock belts rub the * outta my neck. that's even with a shoulder pads.
But yeah your right about that, didn't think about it that way.
Old Jul 29, 2012 | 04:05 PM
Keith B.'s Avatar
Yotarover, have you dropped the belt attachment point on the b-pillar down to the lower of the two bolt holes? When I did mine it really helped eliminate the sawing on my neck.
Old Jul 29, 2012 | 04:21 PM
yotarover's Avatar
No, but i'll will.
Old Jul 29, 2012 | 10:28 PM
combatcarl's Avatar
Mine scratched the poopoo outta my neck, too. Then I noticed a funny round sticker just below it's upper attachment point, and pulled it off, to reveal a small black hole, threaded within, thru which all my days of seat belt-neck-scratching agony would be ended! Lo, it worked! Best 2 minutes spent improving my creature comfort.
djpg2000
Nov 11, 2020 04:56 AM
nvdesertrunner
May 11, 2020 08:18 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
this_guy
Jul 31, 2015 01:27 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
