how much ac oil?
Old Aug 11, 2012 | 01:28 PM
donomite49's Avatar
how much ac oil?
i have a 22re system with a 3.4 compressor.
should i use oil for 4cyl. system or,
should i use oil for the 6cyl. system?
Old Aug 11, 2012 | 03:20 PM
myyota's Avatar
If your going to use this compressor on the 22RE a/c system then drain all of the oil you can out of the 3.4 compressor and refill it with oil for the 22RE a/c system. It is very important to get all the oil you can out of the 3.4 compressor, because the oil used in
R12 a/c systems is not compatable with the oil used in R134a a/c systems.
Old Aug 11, 2012 | 06:38 PM
abecedarian's Avatar
Or, don't drain anything and use an oil compatible with both R12 and HFC-134a.
In general though, you shouldn't add any oil unless you have flushed the system, then there should be a recommendation for how much oil to add for each part of the system: 2oz for the compressor, 1oz for condenser or evaporator replacement, etc.
Old Aug 19, 2012 | 05:04 PM
donomite49's Avatar
fsm said 3.4 ac compressor needs 100 cc of oil after i drained all the oil.
i used compressor oil from the toyota dealership and changed the filter/drier.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
