Where to get bushings?
Old Aug 9, 2012 | 11:15 AM
7mg4me's Avatar
So I am doing this swap https://www.yotatech.com/forums/f115...prings-140015/ on my 90 pickup. I'm on a tight budget, and when I went into a local store they quoted me $60 bucks for a bushing kit. That seems like a complete ripoff for a bunch of "rubber." Is there anybody who knows of any place that i could get them cheaper, or for a better deal? Also what's the best way to get the rear springs off the truck. I hate having to cut things off, but if that's the only way then so be it.
Thanks in advance
Old Aug 9, 2012 | 06:29 PM
abecedarian's Avatar
If you're on a tight budget perhaps you should not start things you can't afford to finish?
Having said that, search online for the bushings. And don't forget to factor in the cost of your time when deciding on the cheapest bushings.
Old Aug 9, 2012 | 07:03 PM
MudHippy's Avatar
Nothin' wrong with cheap. If you know what you're gettin'.
Having said that, what you're really looking for aren't the ones that are made of "rubber". You want polyurethane. And you should be able to get some for less than $60. Maybe not a lot less...but atleast they won't be "rubber". Which are crapola at any price.
Old Aug 10, 2012 | 11:26 AM
7mg4me's Avatar
Thanks for the help. I knew that $60 just seemed outrageous. I'll start looking for the polyurethane.
Old Aug 11, 2012 | 01:49 AM
wyoming9's Avatar
Red face
Now the best way i found depending where you live??
Use a zip disc to cut the ubolts
The front spring hanger use a zip disc cut the head and rear of the bolt off .
pry the spring hanger apart enough to get the spring out.
The shackles some times will come apart sometimes need to be cut.
Have all new hardware.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Pocoyota
Sep 8, 2015 02:41 PM
