O/d switch
Old Aug 2, 2012 | 09:01 AM
SPRAYLINEDUDE's Avatar
O/d switch
Got a 95 4Runner, It had three main shorts..power windows..I fixed..A/C..I fixed..O/D switch has 0.36 volts coming to it. I replaced the push button switch same results? I'm STUMPED
Old Aug 2, 2012 | 09:15 AM
scope103's Avatar
What Sayeth the Good Book? http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf (page 30)
Why did you think the switch was the problem? You should get about 12v (through the indicator light) at one of the switch terminals, ground at the other. If you connect the terminals together the O/D off light should illuminate.
If it doesn't, you've either got a burned-out bulb or a wiring problem. You're probably going to have to pull the panel to check the bulb; when you do that check for continuity back to the switch.
Old Aug 2, 2012 | 10:10 AM
I bought this at a DEA drug seizure auction, they just took the whole inside apart (with-out disconnecting the battery) The windows were shorted out along with the a/c I found the shorts in those. Bulb is good behind cluster... NICE!!!, on the website with the DIAGRAMS!!
Old Aug 2, 2012 | 10:22 AM
scope103's Avatar
How much does a 4Runner, worked over by the DEA, go for these days?
Old Aug 2, 2012 | 05:04 PM
1590.00 $ That was auction fee, tax, title transfer. Its an auto 4x4 v-6 89,917 miles
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
