catalytic converter
Old Jul 29, 2012 | 05:08 PM
CyberStein's Avatar
catalytic converter
My 1995 4X4 has a catalytic converter gasket leak. Are the 2 gaskets on each side of the catalytic converter different?
Also the bolts are all rusted should I just cut them off with a hacksaw and just get new bolts and nuts and use them?
Old Jul 29, 2012 | 05:11 PM
abecedarian's Avatar
If it's stock, the gaskets are the same each end.
If the nuts/bolts are rusted and need cutting to remove them, get new ones.
Old Jul 29, 2012 | 05:14 PM
REDYOTA's Avatar
Yes front and rear is different. Front is a larger diameter. I bought the wrong one last time but pulled the inner ring out and stacked the gasket in.I had to use new hardware in the front got away with reusing the hanger in the rear.
Old Jul 29, 2012 | 05:33 PM
Okay, my bad.
My '91 22re and '88 22re had the same size gaskets front and rear.
I guess some may be different.
Old Jul 29, 2012 | 07:18 PM
REDYOTA's Avatar
Thats my mistake... i picked up another cat from a wheelin buddy. May not have been from a 95. I completely forgot about that. I wondered why it didnt fit. (Went in the parts store and asked for the gasket for my 95 truck.) Looked like an older cat. 95 seal fit the rear but not the front. Sorry... bolt pattern and flang were all the same. Ive got an extra gasket ill go check it against my oem cat and give the part number.
Old Jul 29, 2012 | 07:54 PM
REDYOTA's Avatar
Rock auto part number rear 0396055
Front 0396424
That was for the 22
Rock lists one for the rear but not one for the front on the 3.0
Couldnt find my spare
Old Jul 30, 2012 | 01:50 PM
CyberStein's Avatar
Thanks guys.
Old Jul 30, 2012 | 02:17 PM
IsaiahNarv96's Avatar
you should just buy a new catalytic converter. but our probably the person to do it our self stuff wich is awesome. but i dont know how to do it mslef so i would just buy a new one
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
