How to Access Back of Fuse/Relay Block
Old Aug 12, 2012 | 08:47 PM
RAD4Runner's Avatar
RAD4Runner - Deck lamp Mod
This post covers:
  • Addition of overhead (bright!) deck lamp that does not rely on taillight circuit to use, AND
  • Making both stock and overhead deck lamps independent of tail light circuit.
This will allow turning on either deck lamp without having to scramble (i.e., camping in back) to front, turn taillights on, in order to use any of the deck lamps. Stock deck lamp will remain and will serve as low-level night light, while overhead is for when brighter light is needed.
When I'm done with the mod, I will move procedure/all necessary info to this original post so it will be easier to follow.
Earlier, Terry showed me how to remove this fuse block from bulkhead.
Thanks, Terry!
Last edited by RAD4Runner; Oct 15, 2012 at 09:56 AM. Reason: Post Was Meant for Deck lamp Mod
Old Oct 15, 2012 | 09:49 AM
RAD4Runner's Avatar
Spaghetti Wiring
I finally got started on tapping power for deck lamp into "dome" circuit. Got distracted by the Miramar Air Show - (OORAAH!) so I didn't finish this weekend. Here's work in progress... while I have dash apart, I'm also extending console switch harness to move switches to dash, and make room for future cup holder on console (yeey!) The Gatorade canister will be the foundation of the cup holder. It fits most sizes of coffee mugs. thanks, Bassmastry101 for the inspiration
Spaghetti for Chef
All seats out because also doing sound-proofing. Just more efficient to do these things in parallel so one has better access to wiring.
Old Oct 15, 2012 | 10:16 AM
scope103's Avatar
Please link your posts together
Rad4Runner -
If someone is searching for "how to access back fuse relay block" they'll get to this post. But all they'll learn is that some guy named Terry helped you -- and even though you have the reference in a different color, you don't tell us how to do it! (It sure looks like a link, but it's not.)
I'm not sure why you're creating multiple threads on the same subject, but it's easy (and will help all of us) if you link them together. Use the "link" button in the message box (looks like a globe with a "link" of chain).
To see how to remove the fuse panel: https://www.yotatech.com/forums/f116.../#post51963675
Old Oct 15, 2012 | 02:02 PM
RAD4Runner's Avatar
Originally Posted by scope103
Rad4Runner -
Scope103
Understood.
I tried to rename to "Deck Light Mod" because that was what I was really working on when I got stuck on the fuse block, but somehow, i could not change title. Oh well, will edit. And sort out posts.
-RAD
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jon.r
Jul 11, 2015 03:34 PM
colinmil
Jul 6, 2015 04:03 PM
