22re head to timing cover bolt not lining up!
Old Aug 6, 2012 | 06:38 AM
beach_yota's Avatar
Angry 22re head to timing cover bolt not lining up!
For the past month I've been slowly rebuilding my 22re for my 4runner, and today, as I was putting the new head on, the hole on the timing cover is just slightly off-line with the hole on the front of the head. The head and timing cover are both aftermarket, and I'm stumped on what to do about this
Old Aug 8, 2012 | 06:18 PM
abecedarian's Avatar
Wonder if it may be due to the slightly different heads, timing covers and engine blocks released in the 85-86 range?
Does your engine have a single row or double row timing chain?
Old Aug 10, 2012 | 08:34 PM
beach_yota's Avatar
single row. i think it was due to the ebay timing cover. i drilled out the head to make the hole a lil bigger and i got it to work though.
Old Nov 14, 2023 | 07:15 AM
Learning's Avatar
Did it work without any oil leaking?
I have this similar problem. After expanding the hole on the head to match the hole on the top bolt timing cover, did you have any oil leak after putting all the parts together and run the engine?
Learning
Nov 17, 2023 12:49 PM
Warren Morris
Nov 25, 2015 03:29 AM
copenhagen18
Nov 18, 2011 07:41 PM
ovrebo1
Mar 24, 2009 09:02 AM
RD1970
Jun 25, 2007 05:05 AM
