94 22re backfires and misses
Old Jul 31, 2012 | 09:09 AM
Mikelilly84's Avatar
Hi I have 94 Toyota pickup 4x4 with 22re. I put a new timing chain and guides in it and now under a load it misses pretty bad and backfires sometimes but it idles perfect. Didn't have this problem till I changed the timing chain. Any suggestions? Thanks
Old Jul 31, 2012 | 11:47 AM
myyota's Avatar
Are you sure that you got the timing chain marks lined up properly when you put the new timing chain on ?. What about the distributor, is it set at 5* BTDC ?.
Old Jul 31, 2012 | 03:53 PM
Thanks I'm pretty sure timing chain is lined up properly but not sure on the timing. 5 btdc is where it needs to be? Would the tps need adjusting after the new chain was installed? Thanks for the help.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
TDonkey
Jul 26, 2015 10:14 AM
