PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 [244] 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Hesitation/stalling during acceleration
  2. 86 4runner Tranny
  3. 95 4Runner Cruise Control and Overdrive
  4. rear window mechanism broken plz help
  5. 89 Truck – 22R?
  6. NO Check Engine light
  7. Timing issues...
  8. air intake
  9. head gaskets
  10. ECU compatability
  11. E-Brake Help ASAP
  12. what are these little speakers 91 4runner
  13. Roof possible to repair?
  14. Air pressure split, front to rear on 90-95 Runners
  15. Tranny oil change
  16. Additives
  17. my new ride
  18. compression test
  19. Safety Cancel?
  20. Pro-comp light bar?
  21. Washing the cylinders
  22. need some brake info
  23. Gearing?
  24. new tire sizes
  25. Head Gasket Question
  26. Name this part
  27. How to remove grille?
  28. CEL and Starting Problems
  29. oil filter question
  30. need help choosing two-tone
  31. 22re problems, help
  32. 89 4runner rough running after h/g fix
  33. Steering
  34. No Oil Pressure!!! Major 3.0l Oil Leak
  35. 94 locking hubs HELP!
  36. Vibration decelerating 25 mph & lower
  37. Evil charging problem
  38. Removing intake plenum and manifold...PITA!
  39. vibration issue
  40. Rebuilt 3.0- now oil is circulating through water pump
  41. stronger alternator
  42. bellhousing bolt size....
  43. aisin hubs
  44. 95 3VZE - Camshaft not turning eating Timing Belt
  45. Water Temp Sensor error code
  46. body swap 84 frame to 94 cab.
  47. 2x2 Parts Truck
  48. EFI Trouble
  49. Fuel Filter Removal W/O BL?
  50. Vibration in 4wd
  51. Filler plug rounded Off!!
  52. 89 4Runner Transmission Help Needed
  53. new engine no start?!
  54. Bizzare Idle Problem with a twist
  55. Spare tire Carrier Removal??
  56. 88 22re starter engaging-not turning over
  57. Trailer lights
  58. rear suspension clunk
  59. where to get a Carsound cat?
  60. Engine Removal
  61. air shocks???
  62. 3.0 almost road worthy- ticking noise
  63. 2007 Yotatech calendar is ready
  64. 5 speed
  65. Anybody done a HID conversion on their 2nd gen?
  66. $15000.00 for an '88?
  67. Spindle bushing noise again :(
  68. Slipping Clutch, Rear main leak, Trans leak?
  69. throttle body spacer
  70. Getting hard to shift?
  71. Fading Brake Pedal
  72. instrument cluster not working
  73. oil pressure and mileage??
  74. Starter bolts
  75. 4 wheel woes, can someone advise? my 95 tries to engage 4 wheel while driving
  76. Need pinouts for rear wiper switch
  77. electric fan... stock?
  78. Dash Lights on my Turbo? WTF??
  79. 2WD bumper on a 4WD
  80. My 86 Turbo 4Runner Dilemma
  81. Camo Painting
  82. Basic 3.0 rebuild
  83. Torsion Bar Crankery
  84. Frame Compatiblity
  85. LSPV Removal
  86. Idling RPM question for 22re, 88 4runner, auto
  87. Bigger Leaf Pack vs. Long Shackles
  88. rear glass removal?
  89. brand of shocks
  90. Towing with 92 V6 4runner with auto trans
  91. Checking Codes on a 91 4runner?
  92. Source for Grille to Body Clips?
  93. Engine swap/check engine light?
  94. Curious about strength of a stock Toyota IFS?
  95. sas swap question about gears
  96. Stereo wiring diagram
  97. Problems with shifter after new bushing
  98. crazy electrical problems...coincidence ??
  99. Flucuating idle when brake is pressed.
  100. Lets see your turbo 4Runners and trucks
  101. no acceleration
  102. Horrible noise from front of engine 3VZE
  103. Lift and Tire Questions, help me pick a lift plz
  104. 3.4 swap questions (wiring)
  105. 86 - 95 Pickup
  106. coolant tube gasket question
  107. 22RTE knock questions
  108. Can I run my fan with direct line to 12V?
  109. 22RE Overheating / heater not working - Blown Headgasket?
  110. What are the chances of cracking a 22re block?
  111. Throttle Cable Part#?
  112. 94 Pickup with 22re running problem
  113. Replacing W56 Transmission input bearing?
  114. VERY LOUD TAPPING When enging started.
  115. 1990 22re dies on warm start-up??
  116. funny noises up front
  117. Pics of 2" BL and Sliders
  118. Low idle after idling for a long time
  119. '87 turbo 4runner drivetrain questions
  120. Decklid Mod?
  121. missing at idle
  122. engine/ transmision swap ?????
  123. Turbo Oil pump
  124. bedliner question?
  125. Rear springs front suspension 90 4runner
  126. Brake line fitting Thread size.
  127. Removing radio?
  128. Question about Manual Locking Hubs
  129. stock pressure plate question
  130. Hitch for a 1992 Runner
  131. Random 3.0 Engine Jerk & A/C Amplifier?
  132. Diff Oil
  133. Cruse Control
  134. thermostat bad???
  135. Need help removing throttle body
  136. Need creative replacement of splash guard
  137. NEED advice on 91' 4runner!!!!
  138. Inner Bushing / Needle Bearing
  139. electricale prob with 350 swap
  140. pics of black runner mirrors
  141. What does the "ebrake/battery and at oil temp" lights have in common?
  142. No Spark.. Please Help..
  143. Gas mileage is worse now?
  144. rear window problem
  145. Leaking fuel pressure regulator
  146. Newbie Question?
  147. T-Case Brake: Cable Hook Up
  148. 92 v6 gear ratios
  149. trouble starting
  150. up and down idle
  151. 22R guys needs 22RE help
  152. 22RE Propane
  153. 86 Carb Questions
  154. 60mm TB on a budget...
  155. lift
  156. 2 in lift on 88 4runner?
  157. EGR valve, what other yrs will work?
  158. 89 4runner passenger seat release cable
  159. Automatic Trans Trouble
  160. rear shackles
  161. Removing 87 Front Bumper
  162. Updates on my original rebuild and a BIG thank You to all!!!
  163. Part number (or name) for 22re injector grommet?
  164. 2 inch body lift?
  165. Gear changes in 95 4Runner 3.0 Auto
  166. Intake Manifold Leak maybe? Experts needed!
  167. Roof Rack for 1992
  168. Vibration in rear end 87 runner
  169. Bushwackers installed!
  170. my runners slow evolution...
  171. Fuel Injector Problem on 1994 3.0
  172. Upgrading OEM Headlights
  173. Windows shot out help?
  174. Brush gaurd
  175. Spindle Lubricator® for IFS axle shaft. PICTURES!
  176. Yet another ISR mod...
  177. ECT Warning light on 1992 Runner 4x4
  178. The beginings of a makeover thoughts please!
  179. Ideas for a totaled Runner
  180. Headlight replacement
  181. littlerunner is down
  182. 89 toy troubles
  183. new cylinder head question
  184. No Power At All? Any Ideas I Need Help
  185. 4runner won't start
  186. I need Some Help with Wiring Please
  187. Toyota Parts Cost: Knock Sensor 187.00???
  188. How to fold down the rear seats...?
  189. brake?
  190. power problems
  191. body lift removal question ( searched )
  192. 91 4runner sr5
  193. head swap
  194. 200k mile maintenance
  195. How often do you repack your wheel bearings?
  196. power window problems!!! 89 4Runner (searched)
  197. Tokico Shocks...
  198. Anti-Icing Equipment
  199. need help with Knock sensor issues on 22re
  200. Cam Kits: Engnbldr vs Other
  201. feels like my rear brakes are locking up??
  202. key,locks,ignition cylinder problems
  203. preparing to install a winch.
  204. Turbo or supercharger?
  205. Warn Manual Hubs or OEM
  206. Oh great another vibration thread!!
  207. How do you measure camber?
  208. start problem
  209. Tires too big?
  210. transmission leak
  211. Show off your pics of your 95 runner
  212. Fitting a bigger spare in the stock location
  213. Hard starting, rough idle problem
  214. charging problems getting annoying
  215. 93 p-u interior door panel removal
  216. load sensing proportioning and by-pass valve
  217. Check motor
  218. Does the head have to come of when putting a timing chain on?
  219. Head bolt "A" on 3VZ-FE
  220. new 22re head-lube questions?
  221. Clunking
  222. Radiator options?
  223. Electrical help
  224. vibration issues...91 4runner
  225. 4 wheel drive engages on its own - Any advice would be appreciated.
  226. High beams don't work
  227. *Solution Found* overheating 22re
  228. posi-traction?
  229. power steering
  230. brembo blanks where do you getn them for a 4x4 4runner?
  231. Door- Fender Compatibility
  232. Rebuilding W56
  233. shifter length question
  234. 22re propane conversion
  235. 89 3.0 L pu head bolts
  236. bolt question...
  237. A340H (AUTO) using Dexron III
  238. Carb setup
  239. Fender Flares - Thai vendor
  240. new frame needed
  241. Help ?s for 7mgte swap
  242. long block from DOA --22R--
  243. Starting problems after rebuild
  244. 3.0 problems
  245. What material to make shackles?
  246. BJ lift, Brakes, and some questions
  247. Bj Spacers And T-bar Crank!!?? Please Look!!
  248. BAD gas mileage. new 3VZ-E
  249. bench seats replacement
  250. 1990 4runner fuel line replacement
