Getting hard to shift?
Old Nov 30, 2006 | 05:04 PM
94toyota4x4's Avatar
Ever since I bought the truck I notice its became a little harder to shift, nothing I have to force just feels like it grabs more, espacially going into reverse and first, Im going to check fluids tonight to see if that could be the problem, Ill let you guys know, but what else could it be? Your input will help very much appreciated.
Old Nov 30, 2006 | 05:14 PM
FredTJ's Avatar
Ahhh, how about enough information to begin helping, like engine size, auto or manual tranny ?
It's been decades since I've read minds and I think that I've forgotten how
Maybe just pull the truck a little closer to the computer and maybe we can see it
Fred
Old Nov 30, 2006 | 05:49 PM
Crap dude totally spaced out, Its a 94 yota pickpu 4x4, 22re not sure what tranny is ran in it, you have any ideas?
Old Dec 1, 2006 | 05:54 AM
the_4runnin'_beast's Avatar
I'm assuming M/T...
Old Dec 1, 2006 | 06:05 AM
MMA_Alex's Avatar
probably the w56.
Its probably either the fluid is old, some air in the clutch, or the shifter seat is worn out. or possibly a combination of the three
Old Dec 1, 2006 | 06:48 AM
all_terrain17's Avatar
Hard shifting into reverse is perfectly normal for these trucks. Even the owners manual talks about the problem...
Old Dec 1, 2006 | 07:00 AM
RustBucket's Avatar
My tranny is having similar difficulty, but mainly with the 1-2 or 3-2 shift. I can feel a little grabby before it slides into gear.
I looked at the fluid and it was plenty full - but if the fluid is old will it do this? The oil did not look dirty, but does it lose it's lubrication quality?
Old Dec 1, 2006 | 07:15 AM
4Crawler's Avatar
A good GL-4 gear oil will work better than the more common GL-5 oil in the manual transmission:
- http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Might be worth a shot at changing if you don't know what is in there or how old it is.
Old Dec 1, 2006 | 10:42 AM
MMA_Alex's Avatar
yep, a lot of people like to use MT-90 from redline, and claim to get smoother shifts with it. Next time you have trouble getting it into reverse place it in neutral. and let off the clutch, and then back on and take it from between 1st, and 2nd into reverse. If it goes in smooth that way its probably a clutch issue. If not it would point to one of the other issues
Old Dec 1, 2006 | 02:56 PM
Well It was a bit low I filled it up but no change, how many quarts does the m/t take? O yea, you no the boot where the hydralic pushes the clutch lever, well i tore off, is this bad, is there a clutch adjustment I dont know about by the way, cause this truck is used and abused. thanks for the suggestions so far keep em up
Old Dec 2, 2006 | 10:10 AM
MMA_Alex's Avatar
I think the rubber boot just keeps dust, and mud out. you should replace it when you get a chance.
There are clutch asjustments on the master cyl, to change pedal height, and freeplay, and how much it pushes the master. check the FSM for the adjustment procedures.
not sure on the capacity, but i'd like to know myself. typically 3qts will do ya on a manual, but i'd love to know the actual capacity.
Old Dec 3, 2006 | 08:33 PM
yea looks like that boot has been torn for a while got to get it replaced
Liadrin
Apr 25, 2022 02:54 PM
rusty904
Mar 27, 2017 05:20 PM
Liadrin
Sep 1, 2015 06:44 AM
JAmdor3
Aug 11, 2015 10:53 AM
crashburnoveride
Jul 10, 2015 06:39 AM
