Engine Removal
Old Dec 1, 2006 | 05:09 AM
Cid_4r's Avatar
Engine Removal
Hey guys. I'm new to the Toyota world. I just picked up a
95 4Runner, V6 (3.0), 4x4, Auto Trans. The engine is locked up.
I bought a new one to drop in, but am having trouble getting the
old engine out. I have everything free except the two top bell
housing bolts. Any suggestions how to reach them?
Will this motor come out seperate, or does the transmission and
trans case have to come out with it?
Thanks,
Cid_4r
Old Dec 1, 2006 | 05:49 AM
mt_goat's Avatar
You can get those 2 bolts by moving the engine forward about 3 or 4 inches and going in from the top of the engine bay with your wrench. That's what I had to do.
I know the FSM says to remove the engine /tranny together but unless you have a lot of overhead clearance and an engine leveler, I wouldn't try that myself.
Old Dec 1, 2006 | 05:55 AM
suprathepeg's Avatar
Here is what we did.
1 Remove crossover
2 lift engine
3 remove engine mounts
4 let engine slowly down
5 get in there with a wrench
6 get bandaids for knuckles
7 Throw Wrench at local kid in frustration
8 . . .
Old Dec 1, 2006 | 07:16 AM
Cid_4r's Avatar
Re:
Thanks guys. I'll let you know how it works out...
Old Dec 1, 2006 | 10:40 AM
Pozi's Avatar
I was able to get to the top bolts with a really really long extension and a universal joint for my ratchet.
Old Dec 1, 2006 | 10:44 AM
MonsterMaxx's Avatar
I have a 2" body lift and can get on those bolts with a long extension & swivel no problem.
It'd probably take you less time and bloody knuckles to put a body lift in it than to take the crossover out in the engine bay.
Old Dec 1, 2006 | 11:17 AM
dcg9381's Avatar
I did the same thing.. really long extensions (several) from about the mid point of the transmission.
Old Dec 1, 2006 | 11:57 AM
breknraj's Avatar
Using a 20" 1/2" Rachet, I used a solid 1 foot extension, a wobble 1 foot extension, a wobble 6" extension, a universal joint, and a 17mm six point socket.
It was a complete Rube Goldberg contraption, but it got the job done (stock set-up on my truck).
Old Dec 4, 2006 | 09:02 AM
Cid_4r's Avatar
thanks guys.. after getting back under the truck and taking a better look i was able to get those two bolts with a couple extentions and a universal. thanks for all of your help..
Old Dec 4, 2006 | 01:32 PM
daveo's Avatar
hey Cid_4r i have the exact same truck as you. where did you get your engine? and if you dont mind my asking how much was it?
Old Dec 4, 2006 | 01:34 PM
snap-on's Avatar
i couldnt get to those 2 untill i pulled the entire assmbly half out of the truck. then it was SOOOOO simple 2 little squezzes of the impact gun trigger and they were off in like 2 seconds... (unlike the previous 45 min i had been cussing them by hand)
Old Dec 4, 2006 | 01:48 PM
Tigerstripe40's Avatar
There is a trick to it that I wish I had learned before I pulled the engine out.
Use a LONG extension (AT LEAST 36") and a U-joint on the socket end.
Old Dec 4, 2006 | 05:30 PM
95RunnerSR5's Avatar
i just took the front tires off and used a box end wrench...of course i'm a skinny mug too
Old Dec 6, 2006 | 05:19 AM
Cid_4r's Avatar
I got it from Specialty Automotive in St. Augustine, FL.
only 70k miles on it for $1,500.00
kazuya2416
Apr 5, 2024 02:17 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
