200k mile maintenance
Old Nov 24, 2006 | 08:50 AM
tc's Avatar
tc
I've got about another 1000 miles before my truck rolls over 200k. I 'wheel A LOT. Wondering what I should go through and do so it will be good for another 100k:
Change ALL the fluids (oil, tranny, xfer, diifs, coolant)
Grease spindle bushings (done)
Grease driveshafts (done)
Repack the front wheel bearings
Change the belts (I've got a new alternator to put in anyways)
Plugs/wires/cap/rotor (done not too long ago)
Old Nov 25, 2006 | 12:00 AM
Injohneer's Avatar
You forgot the windshield washer fluid, and.... blinker fluid.
Timing belt/water pump?
Check the hoses... if you're draining the radiator, might as well replace those?
Fuel filter?
Might as well check the brake pads & don't forget the back axle has brakes too...
Wax & shine, post pics, start making the list of stuff to do at 300k.
Old Nov 25, 2006 | 04:54 AM
waskillywabbit's Avatar
Check out the sticky on the recommended maintenance at different service intervals. I'd treat 200K just like any other maintenance interval, yet generally they are in multiples of 15K miles...so you are past your 195K service interval.
Old Nov 25, 2006 | 11:49 AM
tc's Avatar
tc
Timing belt was done at 180k - so it's good for a while.
Fuel filter was replaced when I did the fuel cell. (But good thinking!)
Where is that sticky at wabbit?
Old Nov 25, 2006 | 12:14 PM
It is at the top of the "General Tech" section
https://www.yotatech.com/forums/f123/toyota-maintenace-search-engine-online-fsm-manuals-hunter-balancers-38266/
That should tell you all you want to know.
Old Nov 25, 2006 | 04:52 PM
tc's Avatar
tc
Thanks Wabbit - only good for post '97 though (at least where I saw), but that made me think it's probably in the online FSM...
http://personal.utulsa.edu/~nathan-b.../1maintena.pdf
TURBOrunnerNM
Jul 22, 2015 11:01 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
Vargntucson
Jul 4, 2015 12:15 PM
