2 inch body lift?
2 inch body lift?
I have an automatic 95 4runner with a stick for 4wd(ifthat helps). Can I buy Performance Accessories body lift for my truck but for a manual and buy a automatic transmission drop bracket thingy from 4crawler.??????????? and what else do i need?? WHat do you suggest i do???? Thanks a bunch!
Hey goat i did'nt know if it mattered or not to mention what type of 4x4 selecter i have so i just included it. it sits right next to my automatic trans selector but it does not look like the ones in the manuals like my friends toyota. I'm thinkin 1-1.5 is a better decision now after all the comments thanks. 4Crawler all the way.
I would suggest going with the 1", unless you absolutely need the 2".
The 2" requires quite some extra work besides just inserting the blocks. I had to extend my steering shaft, drop the fan, adjust the front bumper, mess with both shifters, and probably some other stuff that I can't remember. Most of this is not needed if you are doing a 1".
The total process took me about half a day, but 90% of it was adjusting all those other things I just mentioned. A 1" would have probably only taken an hour or two.
And I would also recommend going through 4crawler for everything.
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
read the page.
read the page.
When I did my 3" on my 89 auto, I had to use the drop bracket for the transmission shifter and I had to lengthen my transfer case lever rod. On the 2" I would assume you would have to do the same.
James
James
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Steven.m.paulk
07-24-2015 01:44 PM
