NO Check Engine light
Old Dec 4, 2006 | 11:05 AM
Yotapup's Avatar
My 94 Pickup will not start. I have spark ,timing is set and I have fuel to the cold start injector but no check engine light. I jump the 'W' terminal to a body ground and the check engine light will come on. The manual says a ground or the computer. Any help?
The previous owners had blown some fusible links, and relays,fuses. All those have been replaced but it seems like no fuel to the injectors.
Old Dec 4, 2006 | 11:19 AM
kmcc78240's Avatar
edited: I miss understood, sorry I can't help good luck
Old Dec 4, 2006 | 11:21 AM
Yotapup's Avatar
E1 to TE1 will give you error codes . My problem is : no check engine light unless E1 is jumped to a body ground.
Old Dec 4, 2006 | 02:38 PM
Firefightertaco's Avatar
have u checked the all the fuses there should be some under the dash too. what kind of engine do u have?
Old Dec 4, 2006 | 03:22 PM
Yotapup's Avatar
It is a 22Re. I have checked all the fuses,under the hood and in both kick panels. It can't be a fuse b/c I can ground out the 'W' terminal and the check engine light will come on.
Old Dec 4, 2006 | 03:30 PM
fire5's Avatar
What's it doing when you turn the key?
Old Dec 4, 2006 | 03:31 PM
superjoe83's Avatar
did you check the EFI fuse and relay?
no check engine light means that the bulb is burned out or the computer is not getting any power
Old Dec 4, 2006 | 04:06 PM
Yotapup's Avatar
The EFI fuse is good and the relay has been replaced and checks out.The light will come on when you ground out terminal E1 to the body, so I know the bulb is O.K.
The motor turns over fine with plenty of spark ,no gas odor evident. I do have gas to the fuel rail but not through the injectors , checked by removing line to cold start injector.Plenty of pressure.
The manual refers to a possible ground problem from the check connector.Any idea where this ground is?
How do I check computer to see if power is reaching it?
Old Dec 4, 2006 | 06:09 PM
AUYota's Avatar
sounds like a bad computer to me..
Old Dec 4, 2006 | 06:42 PM
Flash319's Avatar
You distributor pickup might be no good. Pull the distributor, turn the key to the run position and turn the distributor by hand. The injectors should fire as you turn it.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
