*Solution Found* overheating 22re
Old Nov 22, 2006 | 04:32 AM
rodney's Avatar
hello all, a few days ago i posted up https://www.yotatech.com/forums/f116/94-pickup-overheating-22re-99691/ that my 22re was overheating after a timing chain swap. i purchased the complete kit from engbldr.com, which included the all chain components, timing chain cover, water and oil pumps. after installation, i then had an overheating issue at idle.
i thought it was the the thermostat, so i bought an oem toyota one, and it still did not solve the problem. i figured it had to be the waterpump, as i did not have this problem earlier. so, i purchased an oem toyota water pump, and pulled her apart again. i noticed the impellers were quite different. i installed the oem pump and it solved the problem. sorry about the grainy pics, but i used my cell. the wife had the digcam in her possession....
oem pump on left, engnbldr (rock products) pump on right
the toyota pump has much larger/deeper impellers, and the impellers are closer to the housing. the rock pump has more impellers, but they are much smaller, and the tolerences are larger. i would think that the pump moves less coolant at idle, hence my overheating problem.
so, imho, do not buy a rock waterpump, or any other aftermarket pump that looks like this. i am not saying anything about engnbldr.com, as they were helpful when i called, but i guess they switched suppliers and were unaware of the problem.
Old Nov 22, 2006 | 06:10 AM
all_terrain17's Avatar
I HIGHLY doubt that's what your problem was.
Old Nov 22, 2006 | 07:06 AM
dcg9381's Avatar
Valid point, however.. I'm sure Ted will take care of you.
There are a *bunch* of his kits working today w/o any problems... Might point the issue out to him, he's usually very dilligent about searching for the right parts.
Old Nov 22, 2006 | 07:31 AM
rodney's Avatar
why do you say that?
Old Nov 22, 2006 | 08:09 AM
JEDI87's Avatar
I installed the oem pump and it solved the problem.
Obviously it was if it didn't do it afterwards. I had the same problem( not with engnbldr) but with a kragen pump. It actually started knocking. I swapped in a toyota pump and everything worked fine. Glad it was an easy fix.
Old Nov 22, 2006 | 08:27 AM
The impellers on the the Duralast WP I put on mine look just like the ones you got from EB...Never have I seen the temp gauge get past halfway w/ OEM or my current pump under any conditions.
Then again, if all you did was replace the pump like you said, that has to be your problem - assuming you didn't botch the first installation like me
Old Nov 22, 2006 | 08:40 AM
texsurfer's Avatar
looks more like a hamilton beach blender
Old Nov 22, 2006 | 09:01 AM
rdlsz24's Avatar
Amazing what minor differences in parts make. I ran into a similiar situation with new starters I installed earlier this year. Both were for the 22RE, but minor differences in the teeth made one grind like hell and the other work smooth as silk.
Rob
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Logz808
Jul 26, 2015 07:09 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
